| Home > Help Needed / General Tech Chat > boost pressure advice/opinions | |||||||
20th Jun, 2005 at 12:41:16am
just a quicky really. if you guys were running my engine what sort of boost would you put through it? I've got it setup at 12psi at the minute but i'm wondering if it could take more and still manage 4k a year? dont need it as everyday car anymore as i've just sorted out a 216 grandad beast :) On 20th Oct, 2015 Tom Fenton said:
20th Jun, 2005 at 07:30:07am
i reckon 15psi sounds fine, if not more. but yeah 15 sounds about right when you want it, maybe id set it up at 10psi then have a solenoid to switch it to 15psi when i wanted to. |
20th Jun, 2005 at 11:42:06am
must agree with iain
20th Jun, 2005 at 07:55:51pm
cool, cant believe i got used to 10psi so quickly though. now i want more!
21st Jun, 2005 at 01:11:18am
how much further back you reckon i should knock the timing? its at 12 degrees at the minute at 1k with the vac disconnected.
21st Jun, 2005 at 07:57:32am
IMHO
21st Jun, 2005 at 08:09:25am
Set it at 5k, 25 degrees max advance, thats the best way to make sure its spot on |
21st Jun, 2005 at 09:06:37am
you should be able to run at least 17psi no probs, but set up timing on the rollers with some det cans if possible.
21st Jun, 2005 at 08:57:15pm
cool, thats the figure i was after iain, will get it sorted and up the boost next time i'm at the rollers. hopefully before showdown so i can run the 15psi :)
21st Jun, 2005 at 09:27:44pm
On 21/06/2005 09:06:37 turbo hogster said:
with some det cans if possible. Or just use plain ear defenders... Once you lower the baseline noise level, detonation is easy to pick out! On 17th Nov, 2014 Tom Fenton said:
