Home > Help Needed / General Tech Chat > Oil in the exhaust?
1275min
Member #: 538
Frimley, Surrey
Hi All,
As you may of read i had a little trouble getting the engine started in the mini but now it is running fine.
It has not been out on the road yet as no MOT but i have booked it in for a rolling road tune up at Slarks along with an MOT next month.
I noticed a slight oil leak under the car. Not from the normal place, ie engine. It seems to be coming from a joint in the exhaust.
Im hoping its not a seal in the turbo? I dont fancy taking it to Slarks with a duff turbo.
Am i right do you reckon? or another problem?
Take the down pipe of and shove your finger in. If there's loads of oil on the exhaust side then it's the turbo seals.
1275min
Member #: 538
Frimley, Surrey
Ok, I'll check over the weekend. Any one recommend a place to get a new turbo ?
snigger
1275min
Member #: 538
Frimley, Surrey
1275min
Member #: 538
Frimley, Surrey
Ok so i removed the elbow on the end of the turbo and could see the exhuast turbine, it all looked ok nice and dry. A bit of moisture when i started it with my ear defenders on but no oil as such. The puddle under the car that i posted about has evaporated so my guess that it was moisture to start with. Thanks
