Home > Help Needed / General Tech Chat > Idler Shim
Hi all,
I have read the book and it gives a figure of 0.10 to 0.18mm (My book only lists mm). I have put it together with two different gaskets
Gasket one gives me 0.20mm Clearance
Gasket two gives me 0.10mm Clearance
What are peoples thaughts, is a tight clearace a good or bad thing? Do you go loose or tight?
Thanks all
Graham
bakker110
Member #: 9367
Derby
I would have thought it may loosen over time if that's the case go tight. I have no idea if this is the case though. I think I got mine about in the middle by buying a new set from Minispares.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Have a look at this mate..Alan
Main Build
Upgrade to Turbo
Nick
Member #: 154
Midlands
I want a digital torque wrench now :(
nala56
Member #: 9661
Yep there good, me too..
Main Build
Upgrade to Turbo
You definitely don't want it too tight, but then again not too loose either. YOu can get away with a bigger clearance on SC drops though.
I always aim for 3-4 thou. 7 is WAY TOO MUCH!
