Home > Technical Chat > Millers CTV
ian2000t
Member #: 2764
Halesowen
Do many on here use Millers CTV 20/50?
Put some in my Mini yesterday but I'm not sure if whether my Mini really likes it. Was hoping for some thoughts. Mine isn't a turbo-mini (one day hopefully), but after reading through past threads this forum seems more open minded than certain other forums about the CTV oil.
I used to use whatever "decent" Mineral 20/50 I could get - i.e. Millers/Duckams/Comma/Hellfrauds (in that order of preference), but thought I'd give the CTV stuff a try.
The engine was fully rebuilt (1330cc, mspd ph2 cam, std head) about 20/25k miles ago. Gearbox is decent, but for the last year has gotten a bit cranky when it's cold - i.e. doesn't like changing from 3rd down to 2nd. This hasn't been getting any worse, and I just double de-clutch rather than force it.
This morning the gears feel a lot less notchy, but changing down to 2nd or to 1st was much harder. I had to "wait" for the gearbox to "let me" change (or double de-clutch). I've also noticed the oil pressure is higher with the CTV:
Figures (cold idle, cold >2k rpm, warm idle, warm >2k rpm)
Mineral - (60, 60, 40, 60)
CTV - (80, 80, 55, 80)
Is this a problem? I did notice when re-filling the oil, it seemed thicker than normal 20/50.
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats.
this stuff is the dogs bollox imo, worth the money i a performance engine
there was a tech article done by our very own Matt Woods and featured i the mini mag worth a read
metroturbo
Member #: 989
North Yorkshire
Having to double de-clutch sounds more like problems with synchros rather than the oil. Was the gearbox rebuilt at the same time as the engine?
I agree with above, bit of an iffy synchro on 2nd
Cables69
Member #: 10196
I too agree, my box is fairly fresh and i have similar issue's when the oil is cold, but once upto temp its fine
matnrach
Member #: 1074
Northamptonshire
+1
I get exactly the same
20W50 is too thick to be using in this weather.
dig-mini
Member #: 9269
Rotherham
Hope it be ok in mine not running in the winter
Craig
dig-mini
Member #: 9269
Rotherham
Craig
ian2000t
Member #: 2764
Halesowen
My oil pressure readings were a bit out. They are more like:
Cold idle - 60psi
Cold >2k - 70psi
Hot idle - 55psi
Hot >2k - 60psi
Hot >4k - 70psi
Are these figures ok, or are they a little on the high side?
Re: gearbox, I don't think it's too much of an issue - I think it's just showing up the current worn gearbox. When it's warm the gears feel MUCH better - a lot more direct, and less sloppy (technical terms!). When it's cold, I think where the mineral oil would let me force it into gear a little earlier than the worn synchros were ready for, with the CTV I have to just wait until the box is ready. Not really an issue - probably a good thing - I double de-clutch it cold anyway.
About 20/50 being too thick, I know some do use 10/40 without issues but I really wouldn't want to. When I had my Mini (7 years ago) I followed the Hellfrauds book which said 10/40 for topping up. As soon as I did, the small oil leak got bigger, it started burning oil and the oil pressure started dropping off badly (when I took the engine out it was 18psi@4k rpm!), and the gearbox felt rough. When I put the new engine in I was told 20/50 only and no real issues.
good oil pressure!
I'd knock the oil pressure back a little from that, it can push past the turbo seals if its too high.
ian2000t
Member #: 2764
Halesowen
Ok cheers, it's not a turbo motor at the moment, although at some point in the future I'd like to put a GT15 on and make it into a nice torquey motor.
How do you adjust oil pressure? I assume by shimming the relief valve spring?
yep, either stick another copper washer on the relief valve cap or chop a bit off the spring.
