| Home > Help Needed / General Tech Chat > Fuel Gauge Spiking | |||||||
26th Feb, 2013 at 03:24:26pm
Fellas, my fuel gauge keeps spiking when my engines running??
26th Feb, 2013 at 04:23:32pm
could be,
26th Feb, 2013 at 05:00:41pm
check the terminals on the sender are not shorting to earth and giving false readings? |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
26th Feb, 2013 at 08:20:45pm
I had some thing similar, turned out to be tank sender unit.. Alan Main Build
26th Feb, 2013 at 11:03:05pm
Cool,I need to stick some more fuel and make sure its registering whilst the ignition is on then ill double check the sender. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
6th Mar, 2013 at 08:43:05pm
Right ive noticed the Fuel Gauge only does anything while the engine is running? It doesnt spike it just bounces around all over the place, I have a spare gauge with a voltage stabilizer attached so ill try that first. If it stays the same ill get hold of a sender unit this weekend.
13th Mar, 2013 at 01:41:51pm
Results are in, turned out to be the gauge it self. Swapped the new gauge into me clocks and alms well. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
