| Home > Beginners Tech > A good read | |||||||
4 Posts Member #: 10221 Junior Member |
26th Feb, 2013 at 05:42:47pm
I have been reading up on alot of builds in the project section and have found it very informing but I was wondering if there was a "yellow book" on turbo charging.I need to have all the info in front of me before I start buying. |
26th Feb, 2013 at 06:14:08pm
This website really all the info is here. You are best to take your time and decide carefully on spec, cr etc, as people who jump in head first seem to end up wasting a lot of hard eaened on unsuitable parts. The vizzard book has some good general a series info, the metro heynes manual is good for the technical side if things. A good amount of power can be extracted on a reasonable budget with carefully selected parts. Edited by welshdan on 26th Feb, 2013. |
26th Feb, 2013 at 06:30:30pm
check out turbophils site, good solid info to get you started, then look on here for more in depth stuff.
26th Feb, 2013 at 08:47:58pm
Thanks guys,will do. |
![]() 140 Posts Member #: 10115 Advanced Member Sydney, Australia |
28th Feb, 2013 at 11:46:51am
On 26th Feb, 2013 Joe C said:
check out turbophils site, good solid info to get you started, then look on here for more in depth stuff. http://www.turbo-mini.com/ Unreal, perfect for starting off. TurboPhils site is simply laid out and straight to the point! |
