Home > General Chat > Final drives
Chris Dillow
Member #: 6647
Avon Park Class B winner 2010/11
milton keynes
Im after some info on peoples change's in top speeds when they changed there diff ratio.
so what did you find when you went from 3-9 to 4-1???
I've been doing a lot of calculations but im after some real info
Thanks Chris
Edited by Chris Dillow on 26th Feb, 2013.
In short chris, a decrease in top speed and you engine reving its tits off..
can you give us some spec of your motor and wheel size, tyres and what you want the car for road, track or both ?
turbo or N/A ?
1293, 320 cam webber 45 rediculess head force 13" wheels with 175/50r13 yoko a0's
Or is it a 310 cam.? I have your mini mag feature in a moving box atm normally to hand
- 120mph 4th @ 8000rpm with a 3.9 70mph about 4500rpm
- 115mph 4th @ 8000rpm with a 4.1 70mph about 4800rpm
- 111mph 4th @ 8000rpm with a 4.2 70mph about 5050rpm
Edited by Paul R on 26th Feb, 2013.
Chris Dillow
Member #: 6647
milton keynes
Yes Paul it's 310
Well I'm crossing the line at 93-94 @6500ish with 4.1 std 1.1 drops i want to go lower to use peak power @ 7300
If I go 4.1 with 1.04 drops 7500 will be 99.22mph but that's IF the car revs that much, further by dropping the ratio???
Whats your max revs?
Ill answer the next bit for you lol
4.350:1 7500 rpm is 102mph peak power at 97.something mph
Cooper s option ratio
Chris Dillow
Member #: 6647
milton keynes
Carry on Paul. Peak power is 7300 but I can rev it to 8
7320rpm is 99mph
Chris Dillow
Member #: 6647
milton keynes
Yes but will the car be able to get to 7300 in 1/4 that's the question
Yes.
Other option
1.1364:1 drops
4.267 fd
185/60 r13 tyres
7300rpm roughly 95mph
Chris Dillow
Member #: 6647
milton keynes
I like your optimism
No goals then no wins. Can get your goals bigger tyres and more power is the solution. Dont give up keep tying *wink* also read above
4.1 fd
1.1364 drops
7500rpm is 94mph is that not your answer?
You should try a 4.9 cwp,
101 mph at 9000 rpm over the line on the strip with some gas,
94 mph @ 8400 without ,all this was a long time ago,lol
whats the bhp ? chris
130 baldwins
so thats about 100 bhp then, i took my grandaughters dolls pram out of the boot placed it on peters rollers and it made 3 bhp with her pushing it ........ lol
seriously place a 3.6 in there, and i would opt for the 649 cam to go with the diff change
well that sounds like a step backwards....
joe
if you look at the peak torque & hp of the 649 in combination, with that diff, it will nicley shove the car over the line faster
Chris Dillow
Member #: 6647
milton keynes
Ok 4.1 with 1.04 drops it is then
Chris, you want to end up with 4.2 fd
To put another view on this. The lower your FD, the higher wheel torque you have. Seems obvious as that's why we have gears.
To optimise your speed you want to have an FD that allows you to cross the line at maximum rpm. as you are in 4th at high speed, I'd use the max power rpm rather than the 'it will rev to' figure.
So I'd go with the 4.2. this will give 101 mph at 7300rpm. the lower the better.
My car used to cross the line at 7500rpm and 104mph(ish). with the extra power I have I hit the rev limiter at 7.5k way before the line.
thats alvery well assuming the 649 is better than his existing cam... which i dont think it is.
On 26th Feb, 2013 BENROSS said:
joe
Chris Dillow
Member #: 6647
milton keynes
Thanks Wil that's the sort of figures is was after.
Ill be sticking to the 310 thanks
Yoshimura
Member #: 9204
Amsterdam...Edinburgh
if you want to sell the 1:1 drops.....and send them to holland..i'm your guy!!!
greetz bas
