Home > Help Needed / General Tech Chat > Removing the dizzy - blanking plug
Dutchy1978
Member #: 10315
I am removing he dizzy in my SPI and fitting a blanking plug.
Do I need to remove the distributor drive spindle too? I notice that the blanking plug doesn't go all he way down the the shaft an in turn cause he shaft to come out.
Yes, the shaft comes out or it ends up bouncing around in your gear box.
Yes! Take it out quick! Before you forget.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
I second that the first time I forgot made a mess of the shaft, was lucky though no damage to the cam shaft :$ Alan
Main Build
Upgrade to Turbo
Dutchy1978
Member #: 10315
Thanks guys. Thought that's the case. Can only imagine the damage it would do bouncing in and out
no need to imagine, just have a search around the forum to see the evidence
