| Home > Help Needed / General Tech Chat > Best engine oil for turbo mini | |||||||
55 Posts Member #: 9904 Advanced Member |
4th Mar, 2013 at 12:56:55pm
Hi peeps
4th Mar, 2013 at 01:00:38pm
Millers CTV.
In the 13's at last!.. Just |
4th Mar, 2013 at 01:09:43pm
Millers CTV. On 28th Aug, 2011 Kean said:
![]() 190 Posts Member #: 8935 Advanced Member netherlands |
4th Mar, 2013 at 02:18:34pm
isn't the valvoline vr1 20-w50 a good option ? |
4th Mar, 2013 at 04:52:25pm
Millers CTV. Yes i moved to the darkside |
4th Mar, 2013 at 05:44:46pm
I use castrol gtx with zddp additive, seems to like it |
4th Mar, 2013 at 06:12:03pm
Seems like the general consensus is millers ctv. I was using duckhams Q 10w40 synthetic as that was what was recommended by avonbar a few years ago. However millers ctv sounds pretty good even if a little pricey
4th Mar, 2013 at 09:56:02pm
On 4th Mar, 2013 darkviper222 said:
Seems like the general consensus is millers ctv. I was using duckhams Q 10w40 synthetic as that was what was recommended by avonbar a few years ago. However millers ctv sounds pretty good even if a little pricey Thanks again to everyone :) the thing is the cvt is designed for the gearbox as well, and its what £40 a gallon? thats like 0.1% the value of most of our engines, good high quality gearbox oil is like £60 a gallon on its own, i have just done the oil in the daily's engine and box, and the engine oil at £15 a litre is not even the 'best' stuff on the market imo millers cvt IS the best oil on the market, or at least thats how i understand it Edited because i just worked out how much my oil was :( Edited by Brett on 5th Mar, 2013. Yes i moved to the darkside |
4th Mar, 2013 at 10:03:00pm
Thanks Brett you have made a good point actually. It's not worth taking the risk after a full engine rebuild :):) |
![]() 62 Posts Member #: 9439 Advanced Member stoke on trent |
5th Mar, 2013 at 05:02:06pm
What about millers 20/50 classic, say for a mildly tuned beast? It still has the gearbox additives if I understand correctly.
186 Posts Member #: 538 Advanced Member Frimley, Surrey |
8th Mar, 2013 at 11:36:54am
So are we talking the mineral or semi synthetic? |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
8th Mar, 2013 at 04:47:01pm
On 4th Mar, 2013 Brett said:
the thing is the cvt is designed for the gearbox as well, and its what £40 a gallon? thats like 0.1% the value of most of our engines. You spent £40,000 on an engine ?!? Metric is for people who can't do fractions. |
8th Mar, 2013 at 05:06:08pm
the thing is the cvt is designed for the gearbox as well, and its what £40 a gallon? thats like 0.1% the value of most of our engines. You spent £40,000 on an engine ?!? Only if a gallon of oil costs £400 On 26th Oct, 2004 TurboDave16v said:
8th Mar, 2013 at 06:10:46pm
the thing is the cvt is designed for the gearbox as well, and its what £40 a gallon? thats like 0.1% the value of most of our engines. You spent £40,000 on an engine ?!? apparently
although its more likely to be a simple maths error Edited by Brett on 8th Mar, 2013. Yes i moved to the darkside |
8th Mar, 2013 at 08:50:10pm
After 4½ hours in the classroom doing 3-phase theory I just couldn't resist pointing out a mathematical glitch...
8th Mar, 2013 at 11:48:51pm
After 4½ hours in the classroom doing 3-phase theory I just couldn't resist pointing out a mathematical glitch... :) you know what, i had to put it into a calculator and still couldnt work out why i was out, then the penny dropped. Im used to moving the dp 3 places either way never really work out the numbers in between lol
best excuse i can come up with anyway
Edited by Brett on 9th Mar, 2013. Yes i moved to the darkside |
![]() 116 Posts Member #: 4273 Advanced Member stoke on trent |
27th Mar, 2013 at 09:23:22pm
hi all just a quick question had any one use,
1170 Posts Member #: 8636 Post Whore Surrey |
27th Mar, 2013 at 10:13:37pm
Millers ctv 20-50?
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
27th Mar, 2013 at 11:39:46pm
On 27th Mar, 2013 nibble36 said:
hi all just a quick question had any one use, Fuchs Titan Race Pro R 15W-50 Ester Synthetic Oil is A series turbo engine ,also known as Silkolene Pro Race 15w-50, any feed back would be help full thanks Nibble yes i use similar but for the skyline, and a thinner grade for the mini it would be the millers because imo its the correct oil and cheaper On 27th Mar, 2013 WRLondon said:
Millers ctv 20-50? Where's the best place to get it? minispares? although its usually cheaper at shows if you can wait that long http://www.minispares.com/product/Classic/...k%20to%20search edit, i think my last gallon came from ebay tbh Edited by Brett on 27th Mar, 2013. Yes i moved to the darkside |
28th Mar, 2013 at 03:20:16pm
£45 - jesus thats expensive!
Edited by WRLondon on 28th Mar, 2013. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
28th Mar, 2013 at 05:45:04pm
On 28th Mar, 2013 WRLondon said:
£45 - jesus thats expensive! £37 delivered from ebay http://www.ebay.co.uk/itm/Millers-CTV-Semi...e-/400448518807 i'm used to using castrol magnatec as i get it for £10 - 5L! OK just found out MOSS EUROPE sell it for £40 http://www.moss-europe.co.uk/Shop/ViewProd...336&SortOrder=8 i get everything there for cost price, will find out how much it is and may be able to stock up abit if anyones local + wants to save a few quid
(Im from surbiton) millers ctv at moss is nearly £60!!!!!!...... On 26th Oct, 2004 TurboDave16v said:
28th Mar, 2013 at 05:47:14pm
Jjc is demon tweaks. And yes demon tweaks is that cheep too if you collect On 26th Oct, 2004 TurboDave16v said:
