| Home > Help Needed / General Tech Chat > Smoky engine | |||||||
22 Posts Member #: 10140 Member Falkirk Scotland |
5th Mar, 2013 at 04:49:42pm
Just started rebuilt turbo engine and let it heat up to normal temp. It is quite smokey the only thing that was not rebuilt was the turbo. Is this likely to be the culprit. Engine was out of a Metro and was not started prior to rebuild.
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
5th Mar, 2013 at 05:14:13pm
when you say rebuild has it been re-bored and crank ground, if so then it does sound like it could be the turbo.. Alan Main Build
5th Mar, 2013 at 07:59:01pm
Dont forget the rings will need to be bedded in also the cam
Yes i moved to the darkside |
5th Mar, 2013 at 08:11:02pm
What the spec of the engine pistons etc also has the guides been done on the head, we really. Need more information, to give you a decent diagnosis to your problem.
5th Mar, 2013 at 08:33:16pm
Engine on plus 20thou 18 cc forged pistons. Crank ground new shells. Minisport cam. Smoke is dark blue in colour. Head standard with slightly enlarged inlet valves.
5th Mar, 2013 at 09:12:19pm
Has benross says have you had the valve guides and oil seals done these are common causes of oil burning in a turbo engine.. Main Build
5th Mar, 2013 at 09:34:01pm
if the guide seals are years old or the guides are worn it could well be them...........
6th Mar, 2013 at 09:16:14am
Thanks for the reply.New stem seals were used when I built the head. How much and where do I get the turbo done?
6th Mar, 2013 at 03:26:15pm
I would look on ebay for a reconditioned unit and be careful of the places that you find, look at there feed back ect.. or maybe some one on TM may be able to recommend some place they have used, that would be better, sorry I cant help with that.. Alan Main Build
6th Mar, 2013 at 03:30:50pm
And about the guide seals if they are the standard ones that are in the gasket sets, they don't seem to be any good for the turbo engines.. Main Build
