Home > Help Needed / General Tech Chat > 7.5 calliper bolts.
Yo-Han
Member #: 3228
North of the Netherlands
Can somebody please comment?
I pulled my 7.5 brakes appart and also split the calipers.
Found the bolts holding the parts together to be quite short:
Is this normal / as should be?
Thx,
Han
Dazed and Confused....
WRLondon
Member #: 8636
Surrey
should be abit longer than that fella!
that would be for peace of mind as you dont want one of those failing under heavy braking
Reading up on RTS Clutches
mercenary62
Member #: 9937
yep a bit short fella order some new ones
give em hell
Yo-Han
Member #: 3228
Cheers guys.
I was quite convinced myself these were short.
Had a quick look at MS but could not find these.
Can somebody comment on specs of these bolts; iirc these have had a special treatment.
Han
graemec
Member #: 1424
Carnforth, Lancs
These are the kiddies:
they are an exoensive option,
my advice is to take a sample to your local nut bolt shop and try get them in socket head cap acrew, i think the thread is 3/8unf, possibly 7/16 unf
Yo-Han
Member #: 3228
Cheers guys,
Expensive indeed; there is a Fabory close by so I will try Carls advice.
Any comment on the bolts having had a special treatment or should I just try to get some hardened bolts?
Han
You should just need high tensile, grade 8.8 or above.
Cap heads (as Carl suggests) will normally be greater than 8.8, often 10.9 or higher.
The heat treatment and actual alloy "ingredients" is what gives the strength rating.
Rule of thumb on length of thread engagement is 1.25 the diameter as an absolute minimum.
Yo-Han
Member #: 3228
Thanks Rod,
With hardened I ment high tensile.
Will see what local shop comes up with.
Han
graemec
Member #: 1424
Carnforth, Lancs
They're not that cheap, but at least they include the correct seal which doesn't come in the caliper rebuild kit.
The seal is available separately though.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
that's my view you need the seals, will have been a long time compressed so will need to be replaced
Main Build
Upgrade to Turbo
