Home > Help Needed / General Tech Chat > Dellorto Part Throttle Leaning - SOLVED
Folks, im going to take my blue mini for tuning next month at John Sleaths, however in the mean time id like to get the car something like as the close as! Ill get charge via the hour so I want to Save some money at the tuners! *smiley*
Right Ive got a Dellorto DHLA 40H Carb on, the engine is a 998 with an MG Metro Camshaft, now it ticks over loverly, and at Full Throttle it pulls as it should. However at Part throttle to Full Throttle the engine jerks and stutters like its going lean? Now from what ive read this is called the Progression Stage? anyhoo this can normally be solved by upping the Idle Mixture, ive got the idle mixtures out to full (rich) and it makes no difference. Ive checked the size of the Idle Jets and they 58's which i presume are pretty large, the main jets are 160. Is it possible that my Chokes are just too big for the engine? Thus making the adjustment of the Mixture Pointless? Or is there more to it?
Any help would be great
Mike
Edited by MikeRace on 14th Mar, 2013.
eden7842
Member #: 8852
leicestershire
Id say those jets need to be smaller,
The idle adjustment is just idle. Take it you dont know what engine the carb came off?
No afraid not.
This is taken from a dellorto tuning site
The idle jets control the critical off-idle progression between closed throttle and the main jet circuit, it is this part throttle operation which is so important to smooth progression between closed throttle and acceleration and for part throttle driving
eden7842
Member #: 8852
leicestershire
Id whack a nice fuel sipping 44 on there till u get it on the rollers.
There very awkward carbs
mike make sure john has the correct jets for it befor you go, or if not, you may be able to take a few combinations with you
pm me when your going mike, i will come with you for the afternoon out if you wish
what chokes are in it mike ,and what cam in the engine .also what air correctors and emulsion tubes . is there any rpm point where it will respond ok when you tip in the throttle from a steady cruise ,and will it cruise steadily at all rpm ?
wng691s clubby
Member #: 9252
Cleethorpes
if you have vizards book it tells you the correcty choke sizes required with different stages of tuning
Done now needs redoing lol
Not sure what chokes, it does it around 2000 rpm but its a lot worse at low speeds in lower gears, the cam is an mg metro
Here's a vid of it, it does it at 17 secs and around 43 secs
Check out this video on YouTube:
http://youtu.be/Y9DvjTP-mi8
At
Mike
wng691s clubby
Member #: 9252
Cleethorpes
ooo that sounds awful
looks like either the idle jets are too small the acceleration pump circuit isnt working , or the chokes are too big . or its an emmisions carb with the small progression holes .
Right I've just been out to the car, I can't remove what I thought was the chokes but ill need to remove the whole carb so that's a job for sat, but I have a sneaking suspision that I have no chokes fitted, I undid the bolt on the side of the carb and slid out what I think is the aux Venturi about a 1/4 on an inch before it touched the bulkhead, a number said 7848.3 which is indeed the aux Venturi.
Get an SU on there!
Su's are for pansies
One would suit you down to the ground then.
Right then Chepattis!
Ive had the Carb off at Dinner to inspect whats what
Chokes - 32mm
Main Jets - 150 (Evidence of Soldering)
Main Air Corrector - 160
Pump Jet - 33
Idle - 58
Aux Air Jet - No Idea
Yellow Bible Recommends
Choke - 32mm
Main - 145
Air Corrector - 200
Pump Jet - 40
Idle Jet - 55
Aux Air Jet - 4.5
So the Carb isnt a million miles away, I think my next option will be to slap the AEM Gauge in it and do so proper tuning to see whats what......
Given that it's lean on accel I'd look to up the pump jets, that also follows true for the Vizard recommendations.
Yep thats was my initial thoughts, obviously the Lambda Will confirm this.
Ta
Mike
Reet Ave Fixted it!
I removed the Idle Jets and Aux Air Tubes and noticed there was a big difference between the hole. The Jet hole was tiny and the air holes were quite big, So I drilled out the Idle jets to about 0.8mm from around 0.5mm and hey presto the car drives nice and smooth now.
Ta
Mike
Noisy *smiley*
You love it you slaaagggg
wng691s clubby
Member #: 9252
Cleethorpes
nice one
