| Home > Ebay items For Sale > Light verto flywheel | |||||||
10th Mar, 2013 at 01:02:12pm
In the 13's at last!.. Just |
![]() 324 Posts Member #: 9441 Senior Member South Devon |
10th Mar, 2013 at 01:41:37pm
My brother runs their ultra light flywheel and alloy back plate on his MG Metro Cup car. The quality of it's outstanding and I think it's also the lightest pre-verto flywheel you can get. Edited by Tupers on 10th Mar, 2013. |
10th Mar, 2013 at 02:31:45pm
Aaahhhh nearly bought it... must stay on track with goals... Drives
![]() 412 Posts Member #: 9766 Senior Member Warwickshire |
10th Mar, 2013 at 02:38:52pm
This is tempting!
Avon 2010 class c 3rd
10th Mar, 2013 at 03:00:03pm
Now that pre-verto one looks very tempting.
Edited by minimole23 on 10th Mar, 2013. On 7th Oct, 2010 5haneJ said:
10th Mar, 2013 at 03:14:53pm
They are very very cheap which makes me worrie, never want a flywheel to exit its home... Drives
10th Mar, 2013 at 03:27:54pm
Has excellent feedback Crystal Sound Audio said:
10th Mar, 2013 at 03:47:55pm
I have one of his alu pre verto back plates. Had to get Carl to sort a few small things on it. On 11th Feb, 2015 robert said:
10th Mar, 2013 at 04:52:05pm
On 10th Mar, 2013 Paul R said:
They are very very cheap which makes me worrie, never want a flywheel to exit its home... True, but they appear to be being sold by the manufacturer not a supplier who has to add a profit margin, so that will obviously help the cost. On 7th Oct, 2010 5haneJ said:
11th Mar, 2013 at 09:51:25am
Yes the pre verto ultralight looks nice. Has anyone tried them?have just built a 1380 turbo with compression ratio of 8.1:1, also using a big t3 hybrid, one of these might make the engine and turbo spin up a bit quicker, not sure what it would idle like though especially with the low compression and one.of these very light flywheels?? |
11th Mar, 2013 at 09:55:19am
Mike also had to get quite a bit of work done to the setup he bought from this company. I believe he sent him some constructive feedback. Not sure if it was implemented? If something is worth doing, it's worth doing half of. |
11th Mar, 2013 at 09:57:18am
So is someone gonna buy one of the Verto's and give us some feedback If something is worth doing, it's worth doing half of. |
11th Mar, 2013 at 10:05:06am
Yep I had to have loads of material took off the lugs etc, I emailed him and the response I got was "What do you want me to do about it!!!" So i Told him! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
11th Mar, 2013 at 11:58:02am
do you think this is to light for a fast road mini?
11th Mar, 2013 at 12:12:27pm
oneeye has one of the original MED verto's that was about 2.4 kg, thats fine on the road, so this should be ok at a bit less.
11th Mar, 2013 at 12:24:06pm
Do they not sell them now Joe? If something is worth doing, it's worth doing half of. |
11th Mar, 2013 at 12:31:41pm
Yeah, but the early ones were really light, they didnt do that many of them, supposedly they could ovalize when the ring gear went on or somthing. On 28th Aug, 2011 Kean said:
11th Mar, 2013 at 12:50:05pm
Ah right shame.
11th Mar, 2013 at 02:18:06pm
i think the first ever rts ,was around 4lbs heavier ,for the whole assembly with plate ,than a pre verto ultralight minispares setup . Edited by robert on 11th Mar, 2013. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Mar, 2013 at 02:22:11pm
There must have been some serious lightening work done on that cast flywheel then robert. If something is worth doing, it's worth doing half of. |
11th Mar, 2013 at 11:24:53pm
http://www.ebay.co.uk/itm/Mini-Ultralight-...=item20bc0781c0
12th Mar, 2013 at 07:26:29am
I very much doubt Jonspeed make them. Re-sell is probably closer to the mark. On 11th Feb, 2015 robert said:
12th Mar, 2013 at 08:11:00am
I wouldn't use the Jonspeed one. It looks shit and is more expensive.
12th Mar, 2013 at 08:14:08am
Oh. The problem with the early MED verto flywheels is that the interference fit ring gear was interfering so much that it distorted the angle of the lugs.
12th Mar, 2013 at 09:49:28am
On 11th Mar, 2013 NickG said:
http://www.ebay.co.uk/itm/Mini-Ultralight-Aluminium-Verto-Flywheel-only-2-8kgs-/140593562048?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20bc0781c0 jonspeed4minis makes them as well.. do not know much about him Wouldn't touch that! its cast! On 26th Oct, 2004 TurboDave16v said:
