Home > Technical Chat > AP Verto spring ID Colours for RTS
alaskanow0
Member #: 8466
Mansfield
I have searched, but found mixed information on the colour of different springs on the AP verto clutch.
I've just removed a AP Verto clutch from a late 998, it as a green blob of paint. I now have 2 green complete setups & 1 Blue spring. The other green setup also came of another 998 I think, I'm confused as other posts suggest green are 1275.
Any body confirm colours and thickness.
Dark green generally from 998's
Brown generally from 1275's ~2.2mm
Dark blue aftermarket uprated
Light blue Metro Turbo ~2.5mm
Light Green Aftermarket uprated
Thickness varies a lot
Edited by Sprocket on 12th Mar, 2013.
alaskanow0
Member #: 8466
Mansfield
Thanks Colin, that's great. where do you measure them? I'm using Verniers, but getting 2.3mm on the 998 & 2.6mm on the turbo, which is a little toohigh.
Edited by alaskanow0 on 12th Mar, 2013.
alaskanow0
Member #: 8466
Mansfield
So just to confirm 2 x 998 springs with 180mm ap bonded clutch plate, should hold about 180ft/lb. I'm replacing my pre verto Grey setup that's sometimes slips around 16-18psi (160ft/lb)
