| Home > Help Needed / General Tech Chat > Gt17 modification | |||||||
336 Posts Member #: 9941 Senior Member Derby |
15th Mar, 2013 at 07:22:42pm
I am in the process of having my gt1752 turbo actuator bracket cut and re welded and a stub of pipe welded to the inlet side of the turbo( so I can connect a small piece of pipe and air filter.) isit really nessisary that this stub of pipe is welded on air tight as in my mind I don't want any distortion or risk it too much was just thinking of getting it tacked in position as tight as possible and not seam welding it,
15th Mar, 2013 at 08:06:02pm
just take it steady and dont let too much heat build you should be fine, Yes i moved to the darkside |
15th Mar, 2013 at 08:42:44pm
It should be fine, but pre heating the casting first will stop any distortion or cracking when it cools. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
16th Mar, 2013 at 08:36:08am
Why weld it ?
16th Mar, 2013 at 09:03:14am
Well the pipe is already tacked quite nicely so is it really neccissarry to seam weld it?
16th Mar, 2013 at 12:37:57pm
JB Weld then ? |
17th Mar, 2013 at 09:45:43am
What's JB weld mean? |
17th Mar, 2013 at 10:36:55am
Google it |
313 Posts Member #: 9367 Senior Member Derby |
17th Mar, 2013 at 12:34:11pm
Would chemical metal be up to the job I've got some of that! |
17th Mar, 2013 at 02:01:03pm
Looks abit rough to me |
17th Mar, 2013 at 02:43:49pm
My hose tails in my old manifold were chemical metal'd in they were solid but I think I would rather it be welded with the weight of a filter on it! |
17th Mar, 2013 at 03:01:07pm
that techno weld alluminium solder stuff would be good for this. On 28th Aug, 2011 Kean said:
17th Mar, 2013 at 04:32:48pm
If the tacks welded ok, I'd be tempted just to run a bead all the way round.
17th Mar, 2013 at 04:42:52pm
17th Mar, 2013 at 05:27:32pm
How good is that techno weld stuff? Looks impressive. I have only found it on eBay is there any other uk suppliers? |
17th Mar, 2013 at 05:27:34pm
17th Mar, 2013 at 05:51:36pm
its pretty good, fine for somthing like this
17th Mar, 2013 at 06:02:23pm
Techno weld looks good though |
