| Home > Help Needed / General Tech Chat > Should I go pre-verto? And remove brake servo | |||||||
1170 Posts Member #: 8636 Post Whore Surrey |
17th Mar, 2013 at 09:30:03pm
Wondering whether I should change over to pre-verto clutch & remove servo for the space
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
17th Mar, 2013 at 09:34:06pm
Main reasons for going pre verto clutch because of the better clutch selection and lightened flywheel! Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
17th Mar, 2013 at 09:35:56pm
changing the clutch you' just need the pre verto wok cover, plunger, arm, bearing etc, and the bracket. I believe the slave and masters can stay the same.
Edited by Mike-998 on 17th Mar, 2013. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
17th Mar, 2013 at 09:43:56pm
i'd never go back to pre verto for a road car after running an RTS.
17th Mar, 2013 at 09:58:11pm
Ok just done abit of searching and sounds like the best idea!
17th Mar, 2013 at 10:01:04pm
On 17th Mar, 2013 Joe C said:
i'd never go back to pre verto for a road car after running an RTS. +1 could not say it any better Yes i moved to the darkside |
17th Mar, 2013 at 10:09:19pm
Pre vertos are wank. RTS all the way. You can get fancy light flywheels now too.
In the 13's at last!.. Just |
17th Mar, 2013 at 10:16:47pm
Where do I get a rts clutch?
17th Mar, 2013 at 10:25:12pm
Make it, or ask Sproket nicely.
17th Mar, 2013 at 10:32:18pm
I'll ask sprocket nicely :p
