Home > General Chat > long arp head studs
philc
Member #: 1346
bromsgrove
Does anyone know where I can get just the long arp head studs, all i can see is the head stud kits. I need 10. *surprised* thanks
I am led to believe the long ARP stud from the A Series kit is available individually under the part number AJ5.650-1B for 3/8-16 x 3/8-24, overall length is 5.650 studs, and should be available to order from ARP dealers. I'd personally order them from http://www.arrowprecision.com/
Make sure you also ask them for the appropriate 12 point nuts to go with them, and make sure you use the hardened washers that came with the BMW engine under the nuts.
You still need to machine 5mm off of these
Edited by Sprocket on 20th Mar, 2013.
