Home > Beginners Tech > cutting carbon or fibreglass
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
what's the easiest method people have found to cut the carbon and/or fibreglass front ends out there? particularly the headlight and blinker holes?
with a hammer.
miniswordsman
Member #: 6558
for some reason i don't think that'll work...
jamiestevenbell
Member #: 9941
Derby
Dremel with a fine blade in the end worked well on carbon fibre for me!
steve1275
Member #: 951
Bromsgrove
Lots of dust extraction,goggles and facemask,you don't want this dust on you.Then use dremel,angle grinder for big cuts or a jig saw,but you'll use some blades!
'Where does the engine go?'
oli79
Member #: 8480
+1 BFH
On 20th Mar, 2013 apbellamy said:
with a hammer.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Rick.SPI
Member #: 8027
Worked at fairline boats for a hile so lots of grp etc, if you have an air compressor, an airsaw with half a hacksaw blade cant be beaten for neat cuts. I dont have one but used makita jigsaw blade recipricating saw, with metal blades.
Metal blades dont snag or rip like some due to the fine cut, so even if your using a jigsaw try and get metal blades.
Hope that helps.
Rick.SPI
Member #: 8027
Hold your breath while cutting it aswell *wink* lol
miniswordsman
Member #: 6558
okay. well, now I just have to put in for a front end! lol.
I used an angle grinder with 1mm cutting discs... it makes a mess lol
I did the same as Brett in a T Shirt :/
Itchy gained a whole new dimension.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have used all the above. I also use a fine hacksaw blade with some tape on one end to hold it.
http://www.twin-turbo.co.uk
FG experience only.
1mm cutting discs (messy) or very fine (ie, metal cutting) blade in a jigsaw.
The only thing I would add is, when using the jigsaw, whenever possible run it on the matting/resin side of the FG, that way the teeth pull through the gel coat from its exposed surface, not from underneath, so you get a cleaner edge.
Rick.SPI
Member #: 8027
The only trouble with a jogsaw is the 90 degree cutting angle isnt ideal for a neat cut. To get a neat cut you need to be cutting at a small angle so it dosnt snag, but its not always acheivable without certain tools.
steve w
Member #: 1917
AKA chargedzetec
Best for CFRP by far are the quick change dremel cutting discs. The only annoying thing is if you are right handed you get a face of carbon dust!
I just used a 0.8mm cutting disc, holesaws and some drill attachment things that look like conical meat tenderisers but they removed material quickly and neatly.
Johnny
Member #: 6926
Accrington
anything diamond coated is the best idea (for carbon) not sure about fibreglass but im sure its the same scenario. we use diamond coated tools at work and its great. no de-lamination or splinters etc.
for eg
http://www.ebay.co.uk/itm/TZ-6PC-MINI-Diam...=item2c61666562
Edited by Johnny on 21st Mar, 2013.
