Home > Help Needed / General Tech Chat > Converting HIF 44 to turbo
Hoops
Member #: 10338
Huddersfield
Hi there, I have a standard hif44 carb 1 7/8 and I have ordered a rebuild kit for a metro turbo carb and I was wondering what modifications I have to do apart from changing the bits that come in the rebuild kit ? If any , one thing I seem to have noticed is that at the top of the dash pot there is a groove on the turbo carb to take the clamp so the top doesn't blow off ! Any help would be appreciated *smiley*
**Removed the poll for you**
Edited by paul wiginton on 23rd Mar, 2013.
I vote search *wink*
It's been covered recently, I think by Brett
Hoops
Member #: 10338
Huddersfield
Thanks il have a look again I didn't seem to find what I was looking for when I searched before ! What's the vote thing all about ? I'm rubbish at this *hehe!* *hehe!* *hehe!*
You clicked poll instead of topic.
Hoops
Member #: 10338
Huddersfield
Thanks I found some info by changing my wording it looks like I need to get a groove machined in to the top of the body which I can sort out and the rest seems like plain sailing
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
Why?
Hoops
Member #: 10338
Huddersfield
Thanks sprocket , I think I understand what I should be doing now , just to clarify the reason the t piece will be needed in my situation is that I won't have the hole that marries up to the plenum in the nat asp carb ? I also understand about plugging up the unused pipes
Hoops
Member #: 10338
Huddersfield
Hi Brett the grove I was referring to is so the clamp can be fitted to the cap on the top as the nat asp carb does not have one , unless this is not essential ? But I don't want to cause any issues at a later date
No one ever uses the clamp, so the groove is redundant. Don't worry about it
mine sees 22+psi boost every time its out ( thats the current actuator setting( as i crushed my last actuator launching at pod *happy* )) and i have wound it as far as 28psi although now my carb is quite modified and is fitted with position sensors allowing me to log the actual needle position and throttle position
i have never needed the clamp to stop me blowing the damper off the top of the carb
also it started life as an n/a and ran on the track for 6 months with zero mods other than the 'T' peice trick
now its internaly the same as Turbo carb ( just need to drill the passages)
edit, i actually cannibalised a cracked turbo carb when converting mine originally so i have that groove but still dont use it
i also have a different piston settup with sensor fitted that does not have the groove
Edited by Brett on 23rd Mar, 2013.
Hoops
Member #: 10338
Huddersfield
Great news about the clamp ! Are you referring to drilling out the passageway so the t piece is not needed ? And is this a better job or does it not make any difference :)
either / or, drilling it out looks neater and takes 2 mins (then 20mins to clean it all out *happy*), i actually think i use both because mines also go an adjustable lean off valve
longy
Member #: 2727
Bicester
Has anyone got any pictures and dimensions of the groove which needs machining to take the o-ring? does the body and the dashpot need machining?
1972 998 TURBO SLEEPER
the carb runs under a vacuum on an na, under pressure on a turbo, both are a pressure difference vs ambient, the na doesnt need the o-ring and i never used one on my converted carb, i did use a smear of loctite sealant though, mainly through habit
im not sure its really needed but.. the groove needed is (from memory) machined into the carb body not the piston body
no pics or dimensions though im affraid
Edited by Brett on 3rd Apr, 2016.
longy
Member #: 2727
Bicester
Brett many thanks, I'm only planning on running 1 bar max so I might give it a go with some sealant. Cheers
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
