Home > For Sale > Everything Must Go....
wolfy
Member #: 8939
Banbury, Oxfordshire
hello,
clearing out anything & everything mini, i'll add more as i find it.
everything can be collected or posted. postage is on top of the price quoted. all prices can be negotiated. collection from Banbury,Oxfordshire
centre clock conversion loom £25+postage
DSN billet rear trunnions £35+postage
steering boot kit £20+postage
mini clutch cylinder brand new £40+postage
Fiat cinquecento radiator & silicone hoses to fit mini (just need copper joining pipes) £45+postage
Standard 998 distributor, worked when taken off engine £15+postage
Brand new 8.4" brake discs £15+postage
Switch panel, has switches, perfect for chopping up for different switches £5+postage
Brand new HT leads for 998 engine £10+postage
7.5" brake discs with drive flanges, brand new £70+postage (nearly £100 new!)
Brake master cylinder for servo assisted brakes, used, worked when removed £25+postage
Smiffys bits stainless front subframe mounting bolt kit brand new £5+postage
HIF44 SU carburettor, used, took off a scrapped clubman. £60+postage
Mini headlight beam converters, for travelling abroad or just annoying the british public with yellow lights! No cracks, mounting clips there, light scratches £40+postage
Brand new smiths amp meter £35+postage
Smiths water temp gauge, no bulb holder £20+postage
Facet solid state fuel pump 5-7psi "competition" £30+postage
Smiths centre speedo, not mini! Has red area in petrol gauge & trip! Has piece in the back for a reset switch(not included) offers
MED pick-up & bracket kit,comes with bolts and sensor, brand new £60 +postage,
mk1 metro wiper motor, second hand, un-tested. comes with wires £20
Mini 90mph centre speedo £50+postage
Plastic washer bottle £10+postage
cobra black vinyl "classic " low back bucket seats,no rips, marks or anything, on subframes. £200
split webers on longman manifolds, no filters, linkages present, dont know what size they are £600
Engine:
freshly built southam mini metro centre 1380
straight cut close ratio gearbox (tran-x gear kit)
centre oil pick up pipe, 4 pin diff
3.7 cwp
straight cut drops
73.5mm bore, omega pistons, lightened con rods, wedged,balanced,cross drilled crank
new cam followers, water pump, pushrods, brand new 649 camshaft
cooper s rockers, but no cylinder head!
med lightweight backplate, alloy vernier duplex (the stupidly light one) grey clutch, lightweight flywheel, nippon denso alternator (brand new)
£2500 ono
thats all for the moment...remember, if you think its too much, offer me something...the worst i can say is no *wink*
cheers
Edited by wolfy on 18th Apr, 2013.
adrian
Member #: 2726
wakefield
How much posted for the tower?
kappa
Member #: 9854
Hounslow, Middlesex
Interesed in the gear linkage, how much for it posted and any pics
pm sent
josh.evans
Member #: 9145
Northampton
pm sent
powcomnaj
Member #: 7860
Hereford
Would you split the subframe and brakes??
Richspec
Member #: 300
Cumbria
I'm in the market for a good short motor if you end up splitting the engine into bits, looking for a good n/a block, crank, rods, pistons, we dont need cam/flywheel/clutch/head etc.
Rich
Here for the craic..
Supercharged Arden powered
kappa
Member #: 9854
Hounslow, Middlesex
pm'd
wolfy
Member #: 8939
The subframe & brakes can be split.
All pms replied too
Rich, why not buy it and sell them on, recovering your costs *wink*
kappa
Member #: 9854
Hounslow, Middlesex
Got no pm back Wolfy
kappa
Member #: 9854
Hounslow, Middlesex
pm'd again dude
josh.evans
Member #: 9145
Northampton
Got no reply
Richspec
Member #: 300
Cumbria
Thats an option!
(Your a good salesman!)
I'd just need to sit down and price what we could sell some bits for. We're supposed to be reducing the parts hoard by bulding it into another mini, not increasing it!
All pms replied too
Ross-ferry
Member #: 10106
PM'd
Try contacting the right person *wink*
On 26th Mar, 2013 josh.evans said:
Got no reply
josh.evans
Member #: 9145
Northampton
Hi sent 2 pms can how much for the brake setup discs , calipers , flanges can you pm a price thanks josh
josh.evans
Member #: 9145
Northampton
Aha what a knoob just realised doh!!!
tempa
Member #: 10376
hereford
how much are you after for the rolling shell?
dave_39
Member #: 9976
Are the seats still for sale.
wolfy
Member #: 8939
Yes the seats are still for sale
miniallsort
Member #: 1131
engine still up for grabs
wolfy
Member #: 8939
Yes the engine is still avaliable
wolfy
Member #: 8939
first post edited, added loads more. things that have been sold have been removed. thanks
APS
Member #: 10369
Pickering, North Yorkshire
I'll have the subframe mount kit please pal. Pm me with your payment details :)
Alex
www.apsbikes.co.uk
jamiestevenbell
Member #: 9941
Derby
You wouldn't happen to have any kad rear camber brackets
