Home > Help Needed / General Tech Chat > A vs A+ gearbox
turbo1312
Member #: 64
What is the difference between A and A+ gearbox, regarding bearings and layshaft? The reason I'm asking this is that I want to know if minispares evolution ger set for A+ type gearbox can be fitted to A type gearbox. What do you think of this gear set? It costs 250 GBP is it worth the money?
is that the gearkit which uses your old 1st gear?
turbo1312
Member #: 64
Yes that's it.
I'm sure the A and A+ 1st gear used a different pitch and module, hence if the minispares kit was designed to work with a A+ kit, it might not work properly with the A 1st gear...
Email me on davecoxon@totalise.co.uk and i'll send you an email address of a fella who will be able to tell you directly... *wink*
Turbo Shed
Member #: 30
Epsom, Surrey
Dave, are you saying you dont know much about gearbox's?
pinkyandnobrain
Member #: 2588
Pretoria South Africa
New record ? 5 years ! WOW ! *happy*
"Try to take over the world!"
*Clapping* *happy*
turbo hogster
Member #: 178
stowmaket suffolk
i am pretty sure that 1st was the same for a and a+ aswell as reverse and both syncros.
the rest is different though.
personally i would use a a+ case over the a one.
Hoggy is right. 1st is the same. Oh If you write " An A+ case" as you're supposed to we might understand you *tongue*
