| Home > Help Needed / General Tech Chat > Fitting new rear brake cylinders | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
25th Mar, 2013 at 10:26:38am
Hi all, I fitted a pair of new 1/2" cylinders to my backplates, off the car as I cleaned and painted them, apart from having to drill new locating holes for the split pin as they were on the wrong side to standard, when I fitted the E-clips (or whatever you want to call them) they do not hold the cylinders particularly tight against the plate.
www.topcatcustom.co.uk |
25th Mar, 2013 at 10:42:50am
I've had this in the past; if I remember correctly I flipped the E clip round and it gave a better fit, albeit still not that tight |
25th Mar, 2013 at 11:08:21am
His did you fit them? Minispares do a tool which makes it easier and the fit a bit better. On 11th Feb, 2015 robert said:
25th Mar, 2013 at 11:20:58am
I think I used a pair of water pump pliers or similar to press them on from one side, couldn't see a better way, they aren't silly loose, but not very satisfied with the fit. They won't come loose, and they are located well in the hole so may not affect braking, I may be able to nip them up by twisting the clip with long nose pliers or something, I think I tried the clip both ways up. www.topcatcustom.co.uk |
25th Mar, 2013 at 11:30:01am
I hate these poxy things,
25th Mar, 2013 at 11:35:33am
I just bought the tool for this. I regret not doing it 15 years ago. On 13th Jul, 2012 Ben H said:
25th Mar, 2013 at 12:05:30pm
There is an easy way to do these. Take one pair of mole grips, clamp them on to the hub, positioned so the fixed jaw of the grips shoves the wheel cylinder hard against the backplate. Then you've both hands free to fit the clip.
25th Mar, 2013 at 03:28:42pm
What is "the tool"? I just put the cylinder in one end of the vise, popped the backplate over the top of it and was easy to install, just not happy with it!
25th Mar, 2013 at 04:05:02pm
tool:
25th Mar, 2013 at 04:43:06pm
Ah I see, cheers, might know one of those up if it works that well... www.topcatcustom.co.uk |
25th Mar, 2013 at 07:46:37pm
Remove the roll pin and tap M4 or M5 and fit button head set screws. |
25th Mar, 2013 at 08:27:15pm
Thats a bloody good idea I think! www.topcatcustom.co.uk |
25th Mar, 2013 at 09:07:01pm
Why don't they just thread them and stick a nut on it would be much easier... I run a supercharger and I don't care the TB is on the wrong side.
25th Mar, 2013 at 09:22:15pm
I have to admit I once spet ages fucking around with these on a metty... in the end i pulled the pistons out and migged the cunt to the back plate. On 28th Aug, 2011 Kean said:
264 Posts Member #: 8853 Senior Member Bristol |
25th Mar, 2013 at 09:42:23pm
On 25th Mar, 2013 graemec said:
Remove the roll pin and tap M4 or M5 and fit button head set screws. What a top idea! I too have this problem but tapping the hole seems like a great solution Edited by kcchan on 25th Mar, 2013. |
