Home > Help Needed / General Tech Chat > still smoking
turbomini78
Member #: 492
When my car initially starts a huge cloud of smoke comes out the tailpipe. I have had it tuned and it when the carb was set to a normal idle around 700-800 there would be smoke still coming out the tail. If I bump up the idle speed to around 1100 there is no smoke. Also when I get on it in 1st a huge cloud comes out. I have a 1380 turbo w/ just over 2,000 miles. The motor was fully assembled at Avonbar. Any idea what would cause this. It wouldn't bother me too much if it wasn't a daily driver for me. Any input is much appreciated.
was the turbo reconned? the head?
sounds turbo or valve stem related, more likely turbo to be honest
the engine is new so it could be a case of simpley bedding the motor in
but i doubt it...
the second cause could be the turbo but .... did you know the history of this????
if the turbo checks out ok
my bet is a overly rich IDLE mixture
If it puffs on startup it's GUARANTEED the valve guides/valves...
Does it smoke on overrun as well?
