| Home > Help Needed / General Tech Chat > more troubles now hesitating and backfiring- added aem graph | |||||||
![]() 517 Posts Member #: 9931 Post Whore brighton |
26th Mar, 2013 at 08:43:40pm
hi all as a few of you know ive had many problems with my engines etc well i had the car rolling road tested and set up fueling was spot on last week. now i have done 400 miles since it seems to be intermittent from day to day i personally think its the dizzy module.
Edited by charlieb150 on 4th Apr, 2013. |
26th Mar, 2013 at 08:47:27pm
Do you have an AFR gauge? In the 13's at last!.. Just |
26th Mar, 2013 at 08:48:38pm
no :/ i need to get one dont i then that will tell me whats going on |
26th Mar, 2013 at 09:00:16pm
try closing up the plug gaps to .5mm Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th Mar, 2013 at 09:02:23pm
even though there the cooper s ones with the 4 electrodes
26th Mar, 2013 at 09:25:51pm
Spark will only jump to one electrode. Id bin those and put seem decent normal plugs in, and close the gap as per Roberts suggestion. With a standard dizzy etc you may need a smaller gap when on boost. |
26th Mar, 2013 at 09:31:22pm
Why BMW Cooper S plugs? What heat range are they? On 26th Oct, 2004 TurboDave16v said:
26th Mar, 2013 at 09:42:43pm
well at the time i couldnt get any other plugs than the std 6s anywhere so i thought id grab some from bmw next door to my work as there under the same kinda abuse as these engines there( r6 ) on the plug |
26th Mar, 2013 at 09:43:30pm
what plug numbers would you recomend
26th Mar, 2013 at 10:39:25pm
NGK BPR7ES will be fine at 1 bar. |
26th Mar, 2013 at 11:16:07pm
if all the ignition side checks out ? any misfires under boost will be cause by a lean mixture under boost,
27th Mar, 2013 at 07:42:51am
Thanks guys ill Chuck some bpr7es plugs in with a. 5 gap and will order one on Thursday ,ive seen one with boost aswell in the centre is it worth it for 202 quid aem one |
27th Mar, 2013 at 08:10:53am
That's up to you Charlie , IMO I would just purchace the single gauge if you have a good boost gauge already ? But if you have loads of assets. Go for it.
27th Mar, 2013 at 08:54:19am
BKR6EQUP is BMW mini cooper S
Edited by Chalkie on 27th Mar, 2013. |
1170 Posts Member #: 8636 Post Whore Surrey |
27th Mar, 2013 at 09:24:33am
Stupid question then,
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
27th Mar, 2013 at 09:25:54am
Benross do you have the 160 one its just i have nowhere to put it where as if i get theone with boost i can loose th boost gauge car was perfect thismorning on the way to work so will get agauge and see what it says
Edited by charlieb150 on 27th Mar, 2013. |
27th Mar, 2013 at 09:43:54am
I don't know anybody that uses bini plugs specifically.
On 27th Mar, 2013 WRLondon said:
Stupid question then, Does everyone use bini sparkplugs when upping boost? Got some good NGK mini ones? http://www.twin-turbo.co.uk
27th Mar, 2013 at 11:46:31am
get an aem on there asap, i have only ever experience pop back through the carbs with a lean mix, not saying it is lean just dot go driving on boost untill its sorted
Yes i moved to the darkside |
27th Mar, 2013 at 12:00:54pm
Thank brett ill order one tomorow and i m going to wind the boost right down to 10-8psi for wheels day and drive it carfully thanks |
28th Mar, 2013 at 07:50:10am
just orderd this http://www.ebay.co.uk/itm/300733137728?_trksid=p5197.c0.m619 |
28th Mar, 2013 at 09:33:55am
Looks like a useful bit of kit if a bit expensive. |
28th Mar, 2013 at 10:30:17am
Yeah but I thought for the sake of 40quid i can data log boost afr and rpm rather thanjust afr |
4th Apr, 2013 at 06:13:43pm
hi all i brought the aem fail safe gauge and it doesent seem to go past 12.5-1 on full boost is that far out
4th Apr, 2013 at 06:55:05pm
You should be looking for around 12 to 12.5-1 on boost. |
4th Apr, 2013 at 07:16:36pm
thanks phil it is alot richer lower down just when it comes on boost at first 10.5-1 and 15-1 at idle up to 3000rpm |
