Home > Help Needed / General Tech Chat > size my shells
eden7842
Member #: 8852
leicestershire
Mains measure 49.80
And bigs are 43.56
Would that be +40 mains and +30 bigs
Cheers, eden
I'd start by measuring the journals in inches...
any markings on the back of the existing shells?
eden7842
Member #: 8852
leicestershire
1.960
1.714
Its a fresh crank
Like Rob says, they should be marked on the back.
But from your figures -40 for the mains seems right, but you need to re-measure the big ends (especially for ovality) because if your figure is correct, they are a VERY worn -30
EDIT, even with the imperial figures, my last comment applies, big ends are 1.75" standard so you are 36thou under whether you do the maths in metric or imperial
Edited by Rod S on 28th Mar, 2013.
eden7842
Member #: 8852
leicestershire
Its a crank ive had around for a while rod. So ive not got any shells atm.
I shall double check them tonite. I may have disturbed the mic as ive taken them off
eden7842
Member #: 8852
leicestershire
Just check the main was 1.960
And the bigs came out at 1.712
eden7842
Member #: 8852
leicestershire
Think im going to sorce another crank as this one will be a twat to get the 40 mains for It anytime soon
