| Home > Technical Chat > Gearbox rebuild bearings | |||||||
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
28th Mar, 2013 at 10:03:31pm
Just wondering what make of bearings people use for full rebuilds. I was going to order the Minispares kit for about £250, they seem to be OEM quality, but quite expensive. I've also noticed a Minisport kit for £170, which also includes 1,2,3rd gear needle roller bearing, and lock tabs. Why such a difference, I'm assuming quality, but how do you know what's good or not.
Class C 3rd Place Avon 2011 14.18 @101mph |
28th Mar, 2013 at 10:13:20pm
Just go for the expensive bearings. Who knows what the minisport ones are, even if they are 'branded'.
Edited by minimole23 on 28th Mar, 2013. On 7th Oct, 2010 5haneJ said:
28th Mar, 2013 at 10:23:54pm
If you are using standard helical gearset use standard baulk rings. Also the word is that the minisport bearings are non-genuine. If something is worth doing, it's worth doing half of. |
28th Mar, 2013 at 10:40:15pm
If you have the part numbers for the bearings, maybe try a local bearing shop. 9.85 @ 145mph
29th Mar, 2013 at 07:43:22am
On 28th Mar, 2013 John said:
If you are using standard helical gearset use standard baulk rings. Also the word is that the minisport bearings are non-genuine. Standard, as in genuine rover ones, either new or good second hand. or Minispares own. I can get genuine packed rover baulk rings for £17 each, but Minispares claim there copiers are better, something the do with Aug 2011. I guess the Minispares rebuild kit comes with there own brand. I'm a little confused, I just want to build the best box I can. I've strip several boxes to find the best case, gears, synchro etcs. Class C 3rd Place Avon 2011 14.18 @101mph |
29th Mar, 2013 at 07:47:44am
Also what determines good used ones. Above 0.8mm Clearence on cone? Look & feel? Also are the new genuine ones, actually genuine? I assume there no longer in production, so are they made to genuine spec, or last of old stock. A rover/MG trader as some of the last factory rover stock. Are these better? Edited by alaskanow0 on 29th Mar, 2013. Class C 3rd Place Avon 2011 14.18 @101mph |
29th Mar, 2013 at 08:43:52am
I threw away nearly all the bearings inthe kit from minisport. The rollers on the layshaft were ever so slightly shorter. Maybe ok on your average runabout but not on a 200lbft turbo engine. On 26th Oct, 2004 TurboDave16v said:
