Home > Help Needed / General Tech Chat > Carb Connections
1275min
Member #: 538
Frimley, Surrey
Hi Guys,
I was down at SRE yesterday and Neil blanked a couple of connections over on the carb.
The first picture is how it was and the second how Neil left it. Unfortunatley Neil could not complete the set up as the clutch was slipping and the diaphram needs replacing so i need to pop it back to him when this is done but before i do i would like to pick your brains with regard to the carb connections and how you guys have connected yours up and what works really.
Look forward to seeing your posts.
1275min
Member #: 538
Frimley, Surrey
Ok i can not seem to up load them at the mo. I'll try and pop them on here later as i hagve to pop out now!
1275min
Member #: 538
Frimley, Surrey
1275min
Member #: 538
Frimley, Surrey
WRLondon
Member #: 8636
Surrey
wrong pic one sec :)
Edited by WRLondon on 29th Mar, 2013.
Reading up on RTS Clutches
1275min
Member #: 538
Frimley, Surrey
Hi chaps,
Found this again, i used this information to connect the the carb back in 2008.
http://www.bud666.pwp.blueyonder.co.uk/tur...conversion.html
To be fair it does say either blank these off or link together.
Guess I'll be blanking them off then *Rofl!*
wng691s clubby
Member #: 9252
Cleethorpes
i think most people link them as it looks a tad neater thats all
Done now needs redoing lol
1275min
Member #: 538
Frimley, Surrey
Ye I agree but i guess if Neil says that it is restricting the power then i should blank them.
That is the part throttle lean off pipe.
Having it connected or not will have a big impact on your fuel mixture.
It won't restrict power. Lots of people block it off because it can cause a lean mixture during the transition between on and off boost.
1275min
Member #: 538
Frimley, Surrey
Ok, I think that is what was happening hence him blocking them off.
