Home > Help Needed / General Tech Chat > assembling mini speed fast road engine kit troubles
charlieb150
Member #: 9931
brighton
Hi all building a engine for a mate as it all just been machined and reground etc and I cant even get the thrusts in? and the std ones anybody shedany light? Thanks charlie
Try some different thrusts.
Assembeling Minispeed Engine Troubles!
phone minispeed up ...GOOD LUCK!
charlieb150
Member #: 9931
brighton
Haha thought that would be the case
charlieb150
Member #: 9931
brighton
I just got some old ones and still a no go so will get on the phone
to be honest they have given you a load of bits which should all go together perfect! since you bought the kit off them it would be wise to sort this problem with minispeed, because if you start to put it together and alter things minispeed will tell you to fook off......
sadly I have had many peeps engines who was in the same predicament as you.
How can a crank grow? surely standard ones should go in.
charlieb150
Member #: 9931
brighton
Thanks benross hopfully get some results tuesday
I can't see how it's possible to sell an engine in kit form, as you'd need to assemble it to know what size thrusts to use? If they assembled it to work this out then why take it apart again? Lol
Have you read through the Haynes manual, that should give you a good idea of what to look for?
charlieb150
Member #: 9931
brighton
Thats what I was thinking
matty I like you logic .....lol
sadly what happens is they get a load of scrap parts from different engines machine these up.............. sort of!.... fire them in a box and "hey presto you have your go faster road rocket engine"......... the sad part is its left to the poor inexperienced punter to try and fit it all together who indefinitely fails because it just thrown all in a box all wrong incorrectly machined etc ......!!
Fit the thrusts in one side of the crank, then measure the end float accurately with a dial gauge. Measure the other thrust thickness accurately with a vernier and compare measurements
WRLondon
Member #: 8636
Surrey
Sounds like Typical monkey speed to me haha!
Reading up on RTS Clutches
Sometimes parts grow a little during a Nitrocarburizing process.
iirc i had to rub down my thrusts a little
charlieb150
Member #: 9931
brighton
Ill have a another play once they have been called
Cables69
Member #: 10196
this is not the first set of problems ive heard, heavily helicoiled block and camshaft that was fitted was not the one ordered, and waiting for ages to get
