Home > Help Needed / General Tech Chat > dump valve
Zeemax Power
Member #: 393
Oulton Park
Driving my car specially in high revs the dump valve seems to be open and piss air out is it meant to be? and its how avonbar said to have it got the return to the inlet and the dump valve in a T near as pos to the plenium chamber, but it's got to be lossing power piss air out all the time!! would a stronger dump valve be better e.g. piston type*indifferent*
http://www.Zeemax.com
Nick
Member #: 154
Midlands
how much boost are you running? have you plugged up the old valve in the plenum? what dump valve are you using at the minute?
Zeemax Power
Member #: 393
Oulton Park
where abouts you talking about? cos everything taken up at the mo! the only thing that i've heard thats different to some others is a pipe on the carb just above the one you block off and the fuel in. people block that off as well instead of joining it to the one the top which is just in front the plate that holds the accelerator cable like i've done! I'm only running about 5 psi lol sounds like it leaking though i'm running diafram i'm not sure if i'd be better with a A series one though but there masive
Zeemax Power
Member #: 393
Oulton Park
surely its not ment to be like that it sound not very good
Zeemax Power
Member #: 393
Oulton Park
Any ideas
The standard blow off (dump) valve located in the plenum chamber is probably the cause of your problem if it still has the standard spring.
t3gav
Member #: 229
Gavin@minispares.com
kent
this help?
Zeemax Power
Member #: 393
Oulton Park
i think your right but do i have to do to fix it??
Therefore you need an uprated spring, or block it off altogether.
Not rocket science.
dont want to barge in tom & gav but i thought a disassembled pic may be better?*happy*
you can see the spring and the valve seat hole etc
some chaps fit a stronger spring or blank this off with running a 3/8" BSP tap straight down as the hole is the right size to except the tap
then use a taperd hex plug with a little tape ptfe tape on
some pack the spring to give a higher pre load
but the best is just to blank this off permanentley*wink*
hope this ones a little better ?? best i can do with my
steam powerd camera*laughing*
Edited by BENROSS on 28th Jun, 2005.
I welded over the hole in mine
Ben,
Can I borrow this pic off you for referencing in another post?
is the other post about wheely bins?
its yours dave next time i place a pic its got to be a better background
lol..... at jimster *laughing*
having said that if you wait i will take another tomorrow
better laid out and a better background
and replace the one above
Nick
Member #: 154
Midlands
i just packed mine full of 5p's *happy*
Zeemax Power
Member #: 393
Oulton Park
Is there anyway of doing this on the car cause i don't really want to take it off cause i seem to get problems and it works at the mo
Not really... You could drive slower, or wind the boost down. That will solve it.
t3gav
Member #: 229
kent
do you block both holes i cant remember?
there's only one *smiley*
you have to split the plenum zeemax like in the pics
no big deal!
more money than you know what todo with! flash git!
I drilled through the solid half, and threaded it M6. I then put a bolt in, and a flat plate underneath the spring, to allow me to adjust the pre-load on the spring, thus allowing me to still have a degree of overboost protection, but making it easier to set up.
good idea tom
Zeemax Power
Member #: 393
Oulton Park
i've thought of idea!! would this work! since the return is pulling the dump valve open to much to stop that i could put a bleed valve in the line on the return
would it work?
But from what people are thinking its not the dump valve hissing.
but yeah a lot of people find a bleed valve in the vacuum line prevents the diapraghm from being pulled open on idle but still leaves enough pressure for it to work, its commonly seen. THIS IS IF ITS LEAKING ON IDLE ONLY!!
Ive just re-read your original post and you say its higher up the rev range. This will be either a split diaphragm in your DV (they dont last that long!) or it could be as everyone has suggested and its the overboost valve in the plenum thats leaking due to running more boost than it was either handle OR the spring having gone weak over the years.
Edited by iain on 7th Jul, 2005.
