Home > Help Needed / General Tech Chat > edis coilpack position
jdisel
Member #: 9515
ireland
Hi, im at the point in my turbo build where I need to mount the edis bits and im just wondering would there be any problem to mount the coilpack directly beside the alternator. Would it cause any problems with the alternators output or anything. Would mount it elsewhere but caught for space with the intercooler and things and want to keep it as close the the plugs as possible to keep the ht leads neat looking. Any help appreciated.
A job worth doing is a job worth over doing
Chalkie
Member #: 9764
Northamptonshire.
Rover mounted the MPI one not fair for alternator or just mount in on the fly wheel housing?
Wintersurfer has his bolted to the front of the block next to the alternator. No problem.
So have I
jdisel
Member #: 9515
ireland
Ok cool, just wanted to be sure. cheers.
steve1275
Member #: 951
Bromsgrove
Mount the EDIS controller away from heat,I have fried a couple in the past.
'Where does the engine go?'
nala56
Member #: 9661
Sheffield South Yorkshire GB.
It is also said, to mount it on an heat sink such as a piece of aluminium sheet.. Alan
Main Build
Upgrade to Turbo
