| Home > Help Needed / General Tech Chat > Engine advice | |||||||
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
1st Apr, 2013 at 07:28:56pm
Alright folks, well heres where im at so far, ive built an engine for my old road car iv been restoring, but having now just bought a mini van i dont want to go anything ott.
Edited by dev 11 on 1st Apr, 2013. |
1st Apr, 2013 at 07:32:11pm
Compression ratio with 8cc pistons will be very high for a turbo although turbo is the only way to make a relatively reliable 130hp. Stick a flowed head on it and have a nice 100hp n/a I seriously doubt it! |
1st Apr, 2013 at 07:34:40pm
thats what i thought, maybe a well chambered head could get it down enough, |
1st Apr, 2013 at 07:35:45pm
They would have to be huge which I dont think youll manage I seriously doubt it! |
1st Apr, 2013 at 07:39:28pm
think na is the way forward then, that begs another question then do i stick to the 286, or go to a lumpier cam? |
1st Apr, 2013 at 07:41:00pm
How far do the pistons sit down the bore at TDC ? IF they come flush with the deck you're going to be struggling to get the compression low enough to Turbo.
1st Apr, 2013 at 07:44:22pm
theyre not bob on flush with the head, can measure the gap when iv rebuilt it again(re stripped it to acid dip and paint it) |
1st Apr, 2013 at 07:44:43pm
On 1st Apr, 2013 dev 11 said:
think na is the way forward then, that begs another question then do i stick to the 286, or go to a lumpier cam? That all depends on the use of the car and how much money you want to spend. If you go for more cam you need a good head to suit and a Weber carb or twin SUs, then you will need a diff ratio to allow it to rev. This will make a great weekend warrior but not a big mileage engine I seriously doubt it! |
1st Apr, 2013 at 07:47:30pm
it'll never be a mileage motor,
1st Apr, 2013 at 07:50:21pm
286 or higher with a 3.1 wont work. You want a 3.4 minimum for 286, if you go 296 you will want to 3.6 or 3.7.
1st Apr, 2013 at 07:52:09pm
will that bog me down top end if i lower the diff ratio?
1st Apr, 2013 at 07:54:06pm
It will lower top speed lots Edited by paul wiginton on 1st Apr, 2013. I seriously doubt it! |
1st Apr, 2013 at 07:56:02pm
dev IMO go turbo you will need a change of pistons and camshaft also head modd, but it will be well worth it especially not to a have a inflexible untraceable screamer N/A engine,
Edited by BENROSS on 1st Apr, 2013.
1st Apr, 2013 at 07:57:41pm
On 1st Apr, 2013 BENROSS said:
dev IMO go turbo you will need a change of pistons and camshaft also head modd, but it will be well worth it especially not to a have a inflexible untraceable screamer N/A engine, the pistons sitting way down the bore is not practical detonation issues my engines are flush nearly leaving only 0.005" clearance wouldnt say there way down mate but i understand your thinking |
2nd Apr, 2013 at 05:29:17pm
to add another posibility....
2nd Apr, 2013 at 08:33:30pm
Turbo is the only way
In the 13's at last!.. Just |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
2nd Apr, 2013 at 09:16:35pm
was out in mates turbo mini last night and i must say its the future if you have the funds.
