| Home > Help Needed / General Tech Chat > Play in front wheel | |||||||
2nd Apr, 2013 at 03:35:05pm
In the 13's at last!.. Just |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
2nd Apr, 2013 at 03:38:19pm
Can you see the part that's moving? Is it just the wheel, just the drive flange, the whole hub assembly or the whole suspension?
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
2nd Apr, 2013 at 03:42:16pm
tryed the old favorite of seeing if it goes away with the brake on?
2nd Apr, 2013 at 03:43:11pm
Tie rod bushes? If something is worth doing, it's worth doing half of. |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
2nd Apr, 2013 at 03:47:05pm
Have you checked upper and lower arms at the subframe, also tie bar at both ends, another thought I Had play on my wheel bearings because the hub was worn.. Main Build
2nd Apr, 2013 at 05:05:02pm
Typical. 1 min after posting I find it... Steering arm was somehow loose. The lock tabs were in place and secure.
2nd Apr, 2013 at 05:08:17pm
pull the steering arm off and check the dowels!!
2nd Apr, 2013 at 08:51:33pm
Glad you seem to have sussed it.
2nd Apr, 2013 at 10:28:54pm
Dowels seem intact and in good order. The hubs were new from minisport not long ago. I wonder if the dowels were sat on a high spot in the casting and have gradually seated properly? I don't know, but its fixed by tightening two bolts :/
