Home > Help Needed / General Tech Chat > exhaust wrap or VHT exhaust paint.
lee.pb
Member #: 9199
Lancashire
i have been through the search section and still undecided *Confused*
is it better to wrap the exhaust or paint it with VHT exhast paint, this is on a N/A motor to which i have just bought a new maniflow manifold (not stainless).
the last exhaust was wrapped but unsure if to do it again *blush*
my understanding is that they do 2 very differing things; the paint simply withstands high temps whereas the wrap keeps the heat in the exhaust allowing it to dissipate further down the system away from the engine/ under bonnet area
nosaj
Member #: 10176
I personally would do both.
Like Rob said they do two different things.
The paint is more cosmetic, but will help keep them from rusting and then the wrap over the top will insulate them keeping the engine bay and intake cooler.
That's my 2 cents *smiley*
adcyork
Member #: 6807
York
VHT paint, in my limited experience, is useless. Even when applied to shot blasted components it always flakes off in the end. Either wrap or ceramic coat it, the latter of two being rather expensive
oli79
Member #: 8480
Wrap is good if you have room ro get it on there,having tried it on a few projects vht paint is fooking wank how ever its applied and not even worth considering imo
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Agreed on the VHT! It smokes away! lol
minipetrik
Member #: 10373
Walsal
vht usless , wrap it keeps engine bay cooler and the fuel in carbs or injection system stay lots cooler , its way better way to go
Ben H
Member #: 184
Melton Mowbray, Pie Country
Wrap does two things. Keeps the heat in and in my case covers up the shit looking welding, bonus....
http://www.twin-turbo.co.uk
oli79
Member #: 8480
+1 lol
smiffy_no46
Member #: 8079
York
I did my n/a one over winter. Wrapped it then did it with DEI coating stuff. Seems to have worked well, well once it stopped smoking!
Used these so it didnt cost a fortune, it did a fairly tidy job:
http://www.ebay.co.uk/itm/DEI-High-Temp-Si...=item3f17ef7799
http://www.ebay.co.uk/itm/UNIVERSAL-EXHAUS...=item2a13e6d509
lee.pb
Member #: 9199
Lancashire
looks like im using the rest of the exhaust wrap from last time, cheers for the advice guys.
next to open a trend on MJ
Mr Joshua
Member #: 1954
Luton Bedfordshire
Depending on how you intend on using the car I have heard wrap contributing to hear gasket failure.
I got my down pipe chrome plated, six years and it is still mint.
Own the day
Miniac
Member #: 10210
Durban, South Africa
I got my maniflow nickel plated 2 years ago and still looks smart, with a little jap style blueing on the bends.
Life is always a matter of opinion and quite frankly, no ones opinion really matters.
Daniel
Member #: 720
Gloucestershire
How about some Zircotec ceramic coating?
