Home > Help Needed / General Tech Chat > which coolant?
1275min
Member #: 538
Frimley, Surrey
Hi chaps,
Just a quick one.
What coolant do guys use?
Ian form Avonbar recommended Motul he reckons that if you use it neat it can not boil.
I have used Motul but not used it neat.
Today was the first day of the car being road legal so i am getting used to how it runs etc. The temp guage was reading between N and H. Granted i was just poodling around so not alot of air over the engine and i did not have the electric fan on either.
I just thought i would ask what coolant you chaps use and if you dilute it or not?
wng691s clubby
Member #: 9252
Cleethorpes
i use this after that really bad winter we had a couple of years ago i froze my engine http://www.ebay.co.uk/itm/Advanced-Red-Ant...44#ht_637wt_958 good for - 34 but you do loose most of the heating if you have it
Edited by wng691s clubby on 4th Apr, 2013.
Done now needs redoing lol
a coolant that is designed to be used with water is less effective if used neat
i use currently halfrauds coolant and the mini helped alot compared to plane water, in the past i have used toyota red4lyfe ( or what ever its called) i have never seen the inside of an engine soo clean and rust free in all my life,
VAG G11 for engines with little aluminium components or G12 for engines with major aluminium components. Always use at the very maximum a 50/50 mix
There is also a new waterless coolant available which prevents any boil over or internal corrosion as it suggests it contains no watter.
Im not sure your man gave you the best advice using aregular coolant neat since that will have less heat transfer capabilities than a50/50 mix
Edited by Sprocket on 5th Apr, 2013.
