| Home > General Chat > Would this work (twin su plenum) | |||||||
882 Posts Member #: 9854 Post Whore Hounslow, Middlesex |
5th Apr, 2013 at 05:04:31pm
I have just been on TMF forum and seen a guy selling a plenum made for a set of twin Su's.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
5th Apr, 2013 at 05:25:43pm
i believe the problem would be that the turbo hif44 is sealed unit unlike the su's Done now needs redoing lol |
5th Apr, 2013 at 05:28:02pm
Yes, it could be made to work (not talking about the specific plenum as I haven't seen it.
5th Apr, 2013 at 05:28:45pm
On 5th Apr, 2013 wng691s clubby said:
i believe the problem would be that the turbo hif44 is sealed unit unlike the su's Fastest 998 mini in the world? 13.05 1/4 mile 106mph
5th Apr, 2013 at 05:33:48pm
Am I allowed to add the link or the pic on here, so it can be seen? |
5th Apr, 2013 at 05:35:23pm
yeah,
5th Apr, 2013 at 05:38:20pm
excellent, i will add this now |
5th Apr, 2013 at 05:39:00pm
This is the link to the TMF forum
5th Apr, 2013 at 05:40:32pm
No restrictor, so it would not work in a turbo setup. On 11th Feb, 2015 robert said:
5th Apr, 2013 at 05:41:45pm
says dont have permission anyone fancy posting pics Done now needs redoing lol |
5th Apr, 2013 at 05:43:20pm
oh ok, just the guy advertised as a turbo/supercharged set up. But would be quite interesting to see if it was ever done.
5th Apr, 2013 at 05:48:52pm
That and like andy said it has no restricter so youd have to mod it after youve paid out for it. 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
5th Apr, 2013 at 06:31:43pm
On 5th Apr, 2013 apbellamy said:
No restrictor, so it would not work in a turbo setup. On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
5th Apr, 2013 at 07:17:19pm
It's there to keep the presure in the plendinidum higher than inside the car so that the fuel pressure stays right. Probably not needed for efi.
On 5th Apr, 2013 rubicon said:
Didn't have a restrictor in the Rwd mini with the rocker cover plenum , although maybe it's only needed the su On 5th Apr, 2013 apbellamy said: No restrictor, so it would not work in a turbo setup. On 11th Feb, 2015 robert said:
5th Apr, 2013 at 09:38:44pm
I have seen a twin hiff44 setup on a mastro that was running arround 250bhp iirc. Look for snakeii on youtube and look at my video from combe the mastro that spins on the first lap. Drives
6th Apr, 2013 at 09:06:22am
I can't see the pictures, but if it's for an SU not an HIF, a restrictor will be of no use. Because on the SU there is no feed to the float bowl from the carb mouth area.
No restrictor, so it would not work in a turbo setup. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
6th Apr, 2013 at 09:25:46am
They are HIF44's. One turbo and one N/A On 11th Feb, 2015 robert said:
6th Apr, 2013 at 06:21:46pm
On 6th Apr, 2013 wil_h said:
I can't see the pictures, but if it's for an SU not an HIF, a restrictor will be of no use. Because on the SU there is no feed to the float bowl from the carb mouth area. A 'HIF' is a model of carb by SU, SU is the Manufacturer.
The earlier carbs used on Minis were 'HS' while the later carbs were 'HIF', both are SU's
What is a carb anyway?
Edited by Sprocket on 6th Apr, 2013. On 26th Oct, 2004 TurboDave16v said:
