| Home > Help Needed / General Tech Chat > Machining Lugs | |||||||
186 Posts Member #: 538 Advanced Member Frimley, Surrey |
6th Apr, 2013 at 12:37:41pm
Hi All,
6th Apr, 2013 at 12:40:37pm
Just found this on another forum.
6th Apr, 2013 at 01:10:52pm
I had 1mm taken off mine. I originally fitted 3 sets of straps, but am going to take it apart and take one off. Clutch is not fully disengaging in my case. On 11th Feb, 2015 robert said:
6th Apr, 2013 at 01:33:00pm
I thought that more straps reduced the clamping force? I had .7 mm taken off my lugs and have 3 straps fitted. Not got it out on the road with this setup yet. |
6th Apr, 2013 at 01:35:57pm
You need to remove the clutch & flywheel assembly. Put the diaphragm back on & look to see if the pressure part of the diaphragm is sitting flat/horizontal when assembled.
6th Apr, 2013 at 02:42:47pm
yes, as Phil says the spring needs to be flat, or close to it, then when you press the clutch the spring goes "over centre" and is lighter on the foot ad thrusts On 28th Aug, 2011 Kean said:
6th Apr, 2013 at 07:06:14pm
I had 2mm off mine 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
6th Apr, 2013 at 08:31:38pm
Thanks chaps,
6th Apr, 2013 at 08:44:29pm
put a bit of studding throgh the middle of the fly wheel with some big washers, set a dti up and compress it and measure the difference. On 28th Aug, 2011 Kean said:
7th Apr, 2013 at 06:55:56pm
Edited by 1275min on 7th Apr, 2013. |
7th Apr, 2013 at 08:05:01pm
Looking at the assembley in the same direction as the photos. Look at the ring/pressure plate & imagine the left & right hand sides of it are clock hands.
7th Apr, 2013 at 08:50:40pm
No point going over the same ground that someone else has already done, in a very concise manner On 26th Oct, 2004 TurboDave16v said:
8th Apr, 2013 at 05:43:57am
Thank you guys.
11th Apr, 2013 at 04:50:15pm
Hi chaps,
12th Apr, 2013 at 05:45:52pm
Has anyone had to leghthen the metal rod which is driven by the slave cylinder or am I missing a part of the puzzle?
Edited by 1275min on 12th Apr, 2013. |
12th Apr, 2013 at 06:14:48pm
I've had to get a longer rod for mine. On 11th Feb, 2015 robert said:
12th Apr, 2013 at 06:21:11pm
you shouldnt need a longer pin, removing material should have no real bearing on any adjustment needed.
12th Apr, 2013 at 06:26:38pm
Mine is all brand new and need about 5-6mm on the pin. On 11th Feb, 2015 robert said:
12th Apr, 2013 at 08:15:37pm
Mine is also brand new parts. Im Pleased to here you apbellamy also had to do this.
12th Apr, 2013 at 08:21:18pm
Sorry,
13th Apr, 2013 at 07:37:40am
I have 3 straps and my clutch is not disengaging properly. It will be coming to bits again... On 11th Feb, 2015 robert said:
15th Apr, 2013 at 06:16:03am
Clutch is working fine now lads.
