| Home > Help Needed / General Tech Chat > Front panel cutting for FMIC - aka Stupid question | |||||||
1170 Posts Member #: 8636 Post Whore Surrey |
7th Apr, 2013 at 11:48:13am
Probably a stupid question but I've got a zeemax bodykit and a fmic
Edited by WRLondon on 7th Apr, 2013. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
7th Apr, 2013 at 04:26:38pm
The tiebars should be mounted to the subframe, not the front panel!
7th Apr, 2013 at 04:42:39pm
If you were to cut the front panel, I'd want to solid mount the subframe and add strengthening to the mount area on the floor.
7th Apr, 2013 at 05:58:10pm
Good idea
7th Apr, 2013 at 06:58:08pm
Weld some sheet onto the floor on the inside where the mounts bolt to, helps to spread the load and prevent it cracking :)
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
7th Apr, 2013 at 09:20:22pm
As above, it shouldnt be a problem as many minis have removable fronts without bracebars. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
7th Apr, 2013 at 10:43:23pm
From his second post I understand it is the subframe he wishes to chop about.
7th Apr, 2013 at 11:11:33pm
No no
8th Apr, 2013 at 10:41:06am
Can you not just remove the front section of the subby then weld in a tubular piece that takes up less room? Thats pretty much how I made my subframe. However heed Colins about the springyness, it twated me on the knuckles when I chopped it away. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
