| Home > Help Needed / General Tech Chat > Electric water pump and side mounted radiator | |||||||
![]() 178 Posts Member #: 10196 Advanced Member |
7th Apr, 2013 at 02:32:56pm
Firstly apologies if this has been asked before but just wanting to some advice/advice on running and electric water pump.
7th Apr, 2013 at 03:03:49pm
I think I read a while back that Paul uses one. I run a supercharger and I don't care the TB is on the wrong side.
7th Apr, 2013 at 06:02:33pm
Forget the controller, run the pump flat out and put a switch in the rad for the fan to come on as needed I seriously doubt it! |
7th Apr, 2013 at 06:11:51pm
Thats how I was running my setup when it was side mounted. Never had any dramas.
8th Apr, 2013 at 08:29:14am
On 7th Apr, 2013 paul wiginton said:
Forget the controller, run the pump flat out and put a switch in the rad for the fan to come on as needed |
8th Apr, 2013 at 09:28:24am
Rubbish, its just to make more money. Dont listen to anything retail chains tell you - listen to the people who know I seriously doubt it! |
8th Apr, 2013 at 10:55:06am
On 8th Apr, 2013 Johnny said:
I plan on using a Davies Craig setup. They say you should use the controller to prolong the lifespan of the pump On 7th Apr, 2013 paul wiginton said: Forget the controller, run the pump flat out and put a switch in the rad for the fan to come on as needed I thought it was to control the temperature of the engine On 26th Oct, 2004 TurboDave16v said:
8th Apr, 2013 at 12:09:20pm
I plan on using a Davies Craig setup. They say you should use the controller to prolong the lifespan of the pump On 7th Apr, 2013 paul wiginton said: Forget the controller, run the pump flat out and put a switch in the rad for the fan to come on as needed I thought it was to control the temperature of the engine That was my impression, from my experience at work, variable speed pumps dont last any longer than fixed speed. At the pumping stations i work at just helps keep a steady flow so the pumps not banging in and out, which shouldnt be an issue in a car. |
8th Apr, 2013 at 01:19:31pm
The pump just needs to keep the water circulating and the fan regulates the temperature since you dont use a thermostat. Try a controller if you want to but I guarantee you will have it flat out
248 Posts Member #: 7936 Senior Member DK-8450 Hammel. Denmark |
8th Apr, 2013 at 01:40:07pm
So you run it @ 80 l/min. That sound like an avfull lot. Have you tried a little less ? It shouldn´t be nessesary to have that much water pumping to keep you engine cool. "I seriously doubt it" On 8th Apr, 2013 paul wiginton said:
The pump just needs to keep the water circulating and the fan regulates the temperature since you dont use a thermostat. Try a controller if you want to but I guarantee you will have it flat out If i have more toys than you when i die, I WIN |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
8th Apr, 2013 at 01:54:18pm
Look at the specs: (I think this is the one)
Dazed and Confused.... |
8th Apr, 2013 at 02:36:06pm
Look 'doubter' Im not going to justify myself to you, Im trying to give the benefit of experience of a few of us who run an electric pump. Believe me or dont, I dont give a fuck, have you tried it?
On 8th Apr, 2013 paul wiginton said: The pump just needs to keep the water circulating and the fan regulates the temperature since you dont use a thermostat. Try a controller if you want to but I guarantee you will have it flat out I seriously doubt it! |
8th Apr, 2013 at 03:26:08pm
steady on |
8th Apr, 2013 at 04:32:46pm
No, Im not gonna steady on. Im sick of coming up with an idea, researching it, building it, making it work then giving someone the benefit of all that and someone else who has never even tried it comes along and refutes it.
![]() 580 Posts Member #: 9580 Post Whore Surrey |
8th Apr, 2013 at 06:53:40pm
Well said Paul. There must be something in the water these days. It pisses me off when people ask for help or option and then question your advise. If you don't like what you hear you don't need to throw it back in someone's face. I have now got to the point were I just tell people to fuckoff or if at work I put the phone down |
8th Apr, 2013 at 07:05:32pm
On 8th Apr, 2013 shellspeed said:
Well said Paul. There must be something in the water these days. It pisses me off when people ask for help or option and then question your advise. If you don't like what you hear you don't need to throw it back in someone's face. I have now got to the point were I just tell people to fuckoff or if at work I put the phone down Whoa! I havent questioned anybodies advise, tbh i cant see the point now running the controller as essentially all it does is gets the engine upto temp quicker. |
8th Apr, 2013 at 07:16:56pm
It wasnt you Cables I seriously doubt it! |
8th Apr, 2013 at 07:34:19pm
TBH straight talking is the reason I stay here. It truly is a forum that tells you if something works from experience.
8th Apr, 2013 at 07:47:09pm
Rubbish, its just to make more money. Dont listen to anything retail chains tell you - listen to the people who know I have been looking for a new sig ![]()
Edited by madmk1 on 8th Apr, 2013. I have started posting on Instagram also my name on there is turbomk1golf
8th Apr, 2013 at 08:26:33pm
On 8th Apr, 2013 gr4h4m said:
TBH straight talking is the reason I stay here. It truly is a forum that tells you if something works from experience. The mini world forums is full of advice that is bull and as a novice its hard to tell whats good and whats not. I never thought I would build and engine and I doubt without TM I would have tried. I second that, some of the crap i here coming of some people on forums makes me cringe, usually posted by kids in there bedrooms, who have no experience, and havent actually done what theyre telling people to do |
8th Apr, 2013 at 08:31:34pm
i call them chavs
8th Apr, 2013 at 09:06:31pm
back on topic:-
8th Apr, 2013 at 09:41:37pm
Cables if your bored, have a look on my page at how I got on with my side mounted setup.
8th Apr, 2013 at 09:43:14pm
Ive used Minispares Super 2 core and Radtec aluminium with electric pump. Dont bother with aluminium rad, its no lighter once full of coolant and no more efficient. I havent driven it much recently but I used to drive it spiritedly round Milton Keynes for a couple of hours at a time I seriously doubt it! |
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
8th Apr, 2013 at 10:05:46pm
Paul, thanks for info on the thermostat!
internationally known as "big" swede |
