Home > Help Needed / General Tech Chat > T2 oil feed
gdowle
Member #: 9534
Toronto, Canada
Hi, I've got a t2 from an r5 and a pre a plus 998. Does anyone know what oil feed I need? I was going to buy one from minispares with a t but I think that's for a t3 turbo. I don't fancy making anything, just want to bolt it on.
jamiestevenbell
Member #: 9941
Derby
Ill be amazed if you can do a turbo conversion by just skimpily bolting stuff on! Something will need making/modifying I'm sure!
Of course you can, it just won't last very long.
gdowle
Member #: 9534
Toronto, Canada
I've found a t25 water and oil feed kit on eBay. It's the same housing as t2 isn't it?
Mirage
Member #: 119
Water fittings should be M14
Oil fitting most likeley to be 7/16 x 24TPI ( a finer variation of a UNF thread)
