| Home > Help Needed / General Tech Chat > waste spark - mega jolt | |||||||
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
9th Apr, 2013 at 08:26:15pm
am i right in thinking that if you connect a standard timing light onto an edis4 ignition system, if the timing is 10 degrees (standard edis4) that the timing will read 20 degrees because of the waste spark. What the mind can conceive the mini can achieve
9th Apr, 2013 at 08:53:50pm
a standard dumb light will be ok, an electronic one will probably read double as you say. On 28th Aug, 2011 Kean said:
10th Apr, 2013 at 07:09:24am
On 9th Apr, 2013 Joe C said:
a standard dumb light will be ok, an electronic one will probably read double as you say. cheers joe, the lamp i have is one i borrowed off my dad, so is quite old. i think i'll do as it says on many forums and just crank the engine with the MJ disconnected and plugs removed to check that its either 10 or 20. What the mind can conceive the mini can achieve
10th Apr, 2013 at 08:31:09am
It will still flash with the sparks but twice per rotation and should still read 10deg if thats what it is set to but if you watch closely it will also flash 180degrees later where there is no markings on the crank wheel, in reality you can just use it like normal unless it is one of the newer electronic types that might get confused Yes i moved to the darkside |
10th Apr, 2013 at 10:59:03am
You can use modern timing lights with the tachometer and degree advance indicators, so long as you set them for zero degrees. they work just like any other timing light then. On 26th Oct, 2004 TurboDave16v said:
10th Apr, 2013 at 05:34:27pm
If you connect the light to plug 1 then it will fire for 1 and 4. They both fire at the same angle relative to No1 TDC. Therefore it will show the correct angle, but flash twice as often. So the angle shown will be corrct, but if it estimates rpm that will be double.
On 10th Apr, 2013 Brett said:
It will still flash with the sparks but twice per rotation and should still read 10deg if thats what it is set to but if you watch closely it will also flash 180degrees later where there is no markings on the crank wheel, in reality you can just use it like normal unless it is one of the newer electronic types that might get confused http://www.twin-turbo.co.uk
10th Apr, 2013 at 05:57:58pm
of course 1 and 4 are tdc together :$ no idea what i was thinking still works all the same Yes i moved to the darkside |
10th Apr, 2013 at 10:52:01pm
Simple method.
