| Home > Help Needed / General Tech Chat > fuel pressure | |||||||
![]() 55 Posts Member #: 10044 Advanced Member Ballymoney, NI |
10th Apr, 2013 at 07:38:34pm
Hi, ive got far too much fuel pressure at the carb (the gauge spins right round past 15psi!). Im using an mitsi evo fuel pump and malpassi regulator and wondering if i need to restrict the pump with a resistor? ive checked the return line and its not blocked. The return line is also bigger than the feed. Any thoughts? |
10th Apr, 2013 at 07:43:58pm
Silly question, but you've not mentioned it.
In the 13's at last!.. Just |
10th Apr, 2013 at 07:46:09pm
yea ive screwed it fully in and out and still no change. its brand new from minispares |
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
10th Apr, 2013 at 07:57:35pm
Explain how you've got it plumbed in, it sounds like you might have the return feed plumbed in to the float bowl of the carb. |
10th Apr, 2013 at 07:59:00pm
hmmm....
10th Apr, 2013 at 08:00:06pm
try sticking the return into a petrol can and see if its better.
10th Apr, 2013 at 08:00:51pm
ive got it plumbed in as the instruction diagram shows. the bottom connection returns to the tank. |
10th Apr, 2013 at 08:04:08pm
The diaphragm is almost certainly shagged then! Send it back for a replacement. |
hang on.... dosent screwing in raise the pressure?? On 28th Aug, 2011 Kean said:
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
10th Apr, 2013 at 08:27:04pm
yes need screwing out
Done now needs redoing lol |
10th Apr, 2013 at 08:28:40pm
yea i screwed it out first and made no difference. could the pump be too powerful? |
10th Apr, 2013 at 08:29:39pm
what bar is the pump rated at? Done now needs redoing lol |
10th Apr, 2013 at 08:42:40pm
10th Apr, 2013 at 09:21:23pm
not sure what the pressure rating is of the evo pump. the regulator is supposed to handle 60 psi. im sure the pump wouldnt be that powerful. |
19th Apr, 2013 at 03:02:41pm
ok, ive finally got the fuel pressure down to 3.5 psi. my fuel lines were too small, i upgraded them to 8mm ID. Now the problem is that fuel is leaking from the carb and the plenum is filling with fuel from the small hole beside the bolt holes. What could be causing this? Is a seal gone? |
19th Apr, 2013 at 03:28:35pm
float valve knackered or full if shit?
19th Apr, 2013 at 05:44:01pm
On 19th Apr, 2013 jarmour116 said:
ok, ive finally got the fuel pressure down to 3.5 psi. my fuel lines were too small, i upgraded them to 8mm ID. Now the problem is that fuel is leaking from the carb and the plenum is filling with fuel from the small hole beside the bolt holes. What could be causing this? Is a seal gone? that soundls like the float needle valve is not closing propperly. check this by removing the dashpot piston and needle. now, with the fuel pump on there should be no fuel coming up through the jet in the center of the carb. if there is, you'll need to remove the carb and replace the needle valve and its seat. now before you do anything else, change the oil, as ther will be fuel in there for sure. On 26th Oct, 2004 TurboDave16v said:
19th Apr, 2013 at 09:59:08pm
needle valve is not sealing...either through damage, dirt or too much fuel pressure. 9.85 @ 145mph
19th Apr, 2013 at 10:55:39pm
Thanks for the replies. Well today I took the carb off and looked at the float valve which seems ok. Might just replace it and the float anyway. Do you have to set the float height? |
20th Apr, 2013 at 09:18:35am
Did you check to see if it was the float valve that was leaking before removing the carb?
20th Apr, 2013 at 09:25:25am
Float height should be set...but really isnt that critical. Unless it was really bad.
20th Apr, 2013 at 01:24:20pm
I blew into it and the valve seems to close it off when I push the float up ok. Further investigation required I think |
21st Apr, 2013 at 09:27:10pm
All sorted now. Changed the needle valve and float. Holds pressure over 20 psi so good to go. Thanks to all that replied and helped out. Must get a build thread sorted sometime |
21st Apr, 2013 at 11:15:33pm
Your needle valve holds 20psi ?? Holy moly.
22nd Apr, 2013 at 10:59:55am
i was surprised also haha. just need to sort my trigger wheel on the pulley now and hopefully she'll fire. |
