Home > General Chat > fuel pump help please
tomostrash
Member #: 10334
Staffordshire
Hi guys,ime fitting a turbo engine to my mini and require some pump information, ime thinking of using a standard 6psi su pump does any one think it will be ok or do I have to go down the pump and regular route.
wng691s clubby
Member #: 9252
Cleethorpes
pump and regulator have a quick search and youll see what others have done
Done now needs redoing lol
tomostrash
Member #: 10334
Staffordshire
Hi guys,ime fitting a turbo engine to my mini and require some pump information, ime thinking of using a standard electric 6psi su pump does any one think it will be ok or do I have to go down the pump and regular route.
no you need a high pressure pump and regulator.
You need a regulator which raises & keeps the fuel pressure above boost by a preset level, usually around 3-4psi, you also need a pump which will supply this.
Phil.
So any fuel injection pump will do the job, some thing off an older from the scrappy would do :)
New pumps are only £30-40
Really...why even bother with a used one ?
WRLondon
Member #: 8636
Surrey
True that
Facet Red tops seem a popular choice and theyre only £40 odd quid from fleabay
Reading up on RTS Clutches
Facet redtop is not a fuel injection pump. No good for a turbo.
I can't remember who said it originally but it went something like...
"If you want to find out why you cant use a facet redtop in a turbo application, try pissing into an airline"
You need a high pressure pump.
eBay will sell you one for as little as £30...
http://item.mobileweb.ebay.co.uk/viewitem?...Id=300840568578
Edited by theoneeyedlizard on 11th Apr, 2013.
Rick.SPI
Member #: 8027
Ive got a higher pressure pump from a dc2 integra in the spi cradle, was fairly easy to do, could be an option for you?
Edited by Rick.SPI on 11th Apr, 2013.
The easiest way to do it is to get an mpi tank.
Rick.SPI
Member #: 8027
Definitly, but there hard to come by i found.
Johnny
Member #: 6926
Accrington
x5 on ebay at the moment.
Rick.SPI
Member #: 8027
Stand corrected... Haha
