| Home > Technical Chat > EDIS Spark Plug question... | |||||||
1171 Posts Member #: 107 Post Whore Sunny Sussex |
26th Jun, 2005 at 11:22:54pm
sat here playing with the ECU, and a thought crossed my mind...
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
26th Jun, 2005 at 11:41:15pm
I'd say you'll be ok with mini plugs On 15th May, 2009 TurboDave said:
27th Jun, 2005 at 11:42:23am
Been running my squirt for 2000miles with NGK BPR6ES plugs, no problems so far.
27th Jun, 2005 at 11:53:45am
cool, also what leads are best use on a coil pack. I've got the ones that came with it but they are way too short.
27th Jun, 2005 at 12:19:56pm
I just grabbed a load from the scrapyard and fitted the best ones Serria and escort I seem to remember. My coil pack is mounted on the flywheel housing so not to far from the plugs.
27th Jun, 2005 at 02:09:01pm
You should really use ford plugs with the correct internal resistance to work with the coil pack...
AlexF |
27th Jun, 2005 at 05:56:59pm
Resistor plugs are only used to stop RFI/EMI and in no way enhance or reduce power output. And this also applies to resistor leads. So fit what you like if you don't mind the radio noise but make sure you get the correct heat range for your application.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
27th Jun, 2005 at 06:17:07pm
27th Jun, 2005 at 06:35:10pm
Sounds like you should bring a large and empty suitcase (well apart from the famous green jeans) with you to avon park, and take it back full of goodies......so what else do you miss big time from here in the US?
27th Jun, 2005 at 06:50:22pm
Two big suitcases are already planned - luckilly I'm with BMI frequent flyers, so I can take two 25kg cases, as opposed to the conventional one case!
27th Jun, 2005 at 07:05:11pm
I thought american birds are supposed to love the english accent? no good?
27th Jun, 2005 at 07:07:13pm
Id heard that as well! i was looking forward to a trip to the states and get in some bars!! |
27th Jun, 2005 at 07:10:19pm
That was my thought too Iain.....
27th Jun, 2005 at 08:28:40pm
Back to the subject....
27th Jun, 2005 at 08:57:34pm
Tom / Iain - you've gotta do something called 'groundwork' over here... clearly I'm gettign old as I'd rather just drink beer and leer.
27th Jun, 2005 at 09:01:51pm
God damn spadework...........
27th Jun, 2005 at 09:21:30pm
I personally haven’t had any problems running both types of plugs.
28th Jun, 2005 at 09:48:07am
How do you know if a plug is a resisitor plug? are the champion C57c's resistor plugs?
28th Jun, 2005 at 09:21:50pm
longer spark with a rsistor plug
29th Jun, 2005 at 04:42:55pm
ive been told to use bpr7es's in mine |
