| Home > Help Needed / General Tech Chat > Cylinder 4 cooling | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
12th Apr, 2013 at 06:18:23pm
Guys apart from dry decking what other mods can
12th Apr, 2013 at 06:22:55pm
Ive seen the waterways fromt he block to head brazed and redrilled smaller for the middle cylinders so the water will tend to go past cyl 4. On 28th Aug, 2011 Kean said:
12th Apr, 2013 at 06:33:43pm
Thanks joe, what about this heater trick?
12th Apr, 2013 at 06:57:04pm
this is a massive bowl of contention Nic, and all kinds of plumbing sort of fixed has been employed by many people, engine builders and alike over many years trying to fix a problem thats not there ............... its not needed in my book. most are based on upping the horsepower massivley and still using the standard pipe work plumbing for a 60 hp engine
12th Apr, 2013 at 07:04:18pm
Epic reply it does! I now front mount raded.
12th Apr, 2013 at 07:28:21pm
if you have a side mounted rad yes!it doesent matter as the volume of water flow is massive ...... the diffrence in warm up time is not noticable,
![]() 270 Posts Member #: 69 Senior Member Coventry |
12th Apr, 2013 at 09:30:56pm
In Ministox racing, the heater take off, I plumb the heater take off from number 4 back into a cut down bottom hose as a top hose, gets heat out of number 4 end and back to the rad, on the hot into it side, putting hot water into the cold coming from the rad doesnt make sense. |
12th Apr, 2013 at 10:38:38pm
yes you have a point, thats on a balls out sreamer which get very hot quickley!
13th Apr, 2013 at 06:13:41am
"insane" says the nutty proffesor On 26th Oct, 2004 TurboDave16v said:
13th Apr, 2013 at 07:41:58am
13th Apr, 2013 at 08:45:27am
haha thanks benross for the expert advice..
14th Apr, 2013 at 08:05:24pm
Yes Ministox is a little nuts like that, 0 to flatout in second gear for 10 laps then park it up again... |
