| Home > Help Needed / General Tech Chat > again a needle question | |||||||
51 Posts Member #: 10080 Advanced Member Holland, Eindhoven |
12th Apr, 2013 at 06:21:34pm
Gentlemen,
12th Apr, 2013 at 06:31:58pm
usuall a standard turbo BDD needle BUT ..... any needle will do, to start it and run it not under load, so you can get it to a rolling road and then the operator if he is worth his salt can optimise the fueling correctly!!! along with the ignition timing,
12th Apr, 2013 at 07:44:34pm
the bdd is a good all round needle but will need alot of work for a blow through charger settup imo,
Yes i moved to the darkside |
13th Apr, 2013 at 01:15:05pm
Do you have an adres where to buy a system? |
