Home > Technical Chat > Metro inlet manifold or this one....
Custard
Member #: 8215
Rayleigh
I'm making a exhaust Mani so is this a better inlet manifold to use? Gives me more clearance in the bulkhead and looks better flowing?
Ta
Dave the Cake
Don't think it makes any difference as the air is being forced in rather than drawn in, so use whatevers best!
i like to think the more abrupt angles on the turbo manifold was bl/rover's (who ever it was) attempt of solving / helping fuel distribution between all cylinders
look at the spi/mpi manifolds aswell there quite square and have port deflectors
other than that i suppose its down to opinion ( i would tend to lean towards the turbo one as we know it works ok)
yes iam with bret, leyland got the turbo manifold spot on in many repsects
Custard
Member #: 8215
Rayleigh
Would be interesting to do some back to back Dyno tests. It was mainly the divider web that looked more efficient to me.
Dave the Cake
Nic uses the NA one on his. So we know that works too.
alaskanow0
Member #: 8466
Mansfield
I'm using a MG n/a Matty one, with no issues. Good power v boost. Also used the N/a one on my my SC single point wet manifold setup, worked perfectly and opened up to 50mm.
Edited by alaskanow0 on 16th Apr, 2013.
