| Home > Help Needed / General Tech Chat > Mini won't fire... Please help guys! | |||||||
![]() 412 Posts Member #: 9766 Senior Member Warwickshire |
17th Apr, 2013 at 06:28:18pm
Hope someone can help ... Mini used to eat through standard starter motors so invested in a hi torque jobbie. Since then it struggled to start and now refuses to fire!
Avon 2010 class c 3rd
17th Apr, 2013 at 06:30:41pm
Check the engine earth Rich. |
17th Apr, 2013 at 06:35:38pm
Whats the battery voltage have you tried to jump start it? Yes i moved to the darkside |
17th Apr, 2013 at 06:39:45pm
12.5 v showing and drops to 11.8 when cranked tryed hooking another good battery to it and still no joy
17th Apr, 2013 at 06:40:25pm
Engine earth is all good too .. It's driving me mad Avon 2010 class c 3rd
17th Apr, 2013 at 06:44:56pm
Is the battery lead shorting against anything? On 26th Jan, 2012 Tom Fenton said:
17th Apr, 2013 at 06:49:27pm
I had a similar problem years back, turned out to be a knackered starter that was brand new from minispares. Can you try another from someone else? |
17th Apr, 2013 at 06:49:55pm
Battery leads all intact
17th Apr, 2013 at 06:52:02pm
If its not sparking when cranking is it seeing a crank signal? Does the crank signal run your fuel pump aswell? |
17th Apr, 2013 at 06:54:28pm
The fuel pumps on its own switch separate from the ecu... This is the crank oscilloscope
17th Apr, 2013 at 06:55:17pm
Is your ecu getting power when cranking? if you've changed the wiring round it may not be connected to the starter wiring bit. On 11th Feb, 2015 robert said:
17th Apr, 2013 at 06:56:54pm
Vr sensor connected the wrong way round? The double missing tooth is the usual sign Yes i moved to the darkside |
17th Apr, 2013 at 06:58:05pm
The only thing that's changed is the starter motor since it used to work (but the starter was crap)
17th Apr, 2013 at 07:00:42pm
Did you miss a live somewhere? As all these link at the starter.
In the 13's at last!.. Just |
17th Apr, 2013 at 07:06:53pm
Just double checked and everything's there .. Live from battery, from starter to alternator and the signal wire
17th Apr, 2013 at 07:08:20pm
Vr is as its always been on a plug Brett Avon 2010 class c 3rd
17th Apr, 2013 at 07:14:34pm
Starter bolt too long and now fouling the flywheel?
Edited by theoneeyedlizard on 17th Apr, 2013. In the 13's at last!.. Just |
17th Apr, 2013 at 07:18:18pm
It cranks ok but just no spark when cranking. Tested through ecu and it sparks Avon 2010 class c 3rd
17th Apr, 2013 at 08:27:50pm
How does the coil get its power? Sounds like theres not enough juice there on cranking? Yes i moved to the darkside |
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
17th Apr, 2013 at 08:35:40pm
I'm with Brett on this one. Try different 12v feed to coil pack. Class C 3rd Place Avon 2011 14.18 @101mph |
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
17th Apr, 2013 at 08:43:35pm
sounds like the coil is either underpowered or knackered Rich. Do you have a spare you can try? |
17th Apr, 2013 at 09:00:30pm
Had initial problems with megajolt on mine, turned out the vr sensor had swarf on it. Woth a check... |
17th Apr, 2013 at 09:26:22pm
Ill try the feed to the coil when I'm up there tomorrow night .. The coil was working when ran a test through the ecu though? Strong spark too Avon 2010 class c 3rd
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
17th Apr, 2013 at 09:32:19pm
Have you tried repeatedly swearing at it very loudly? doesnt always solve the problem but often makes me feel better!
Edited by oli79 on 17th Apr, 2013. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
1170 Posts Member #: 8636 Post Whore Surrey |
17th Apr, 2013 at 09:37:59pm
Think Oli has got this one sorted Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
