| Home > Beginners Tech > Supercharged 1330... A few Questions... | |||||||
12 Posts Member #: 10403 Member |
18th Apr, 2013 at 06:40:39pm
Hi Guys,
19th Apr, 2013 at 01:38:33pm
Well for the highest power output a turbo is the way to go but that isn't for this thread, plenty of info search on here.
Edited by gr4h4m on 19th Apr, 2013. I run a supercharger and I don't care the TB is on the wrong side.
19th Apr, 2013 at 02:43:32pm
Ahh ok great information! |
19th Apr, 2013 at 03:13:20pm
A few edits as the reply was from my phone I run a supercharger and I don't care the TB is on the wrong side.
75 Posts Member #: 1956 Advanced Member |
20th Apr, 2013 at 07:10:35am
For the clutch:
976 Posts Member #: 3228 Post Whore North of the Netherlands |
23rd Apr, 2013 at 10:15:26am
On 20th Apr, 2013 remko said:
For the clutch: The standard turbo clutch isn't good enough. The torque of a supercharged engine is massive! Been there, done it... I switched succesfully to an non verto grey + rally plate. And last but certainly not least: make sure your ignition timing is OK! It's better for your pistons :) Regards, Remko Supercharged Pickup Or search RTS; less stress on the thrust bearing. Ignition timing is a good point; Megajolt or Nodiz are popular Dazed and Confused.... |
![]() 11 Posts Member #: 1218 Member |
28th Apr, 2013 at 08:03:43am
Id avoid the weber and go for some sus
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
28th Apr, 2013 at 09:19:45am
Make your own inlet and use some bike carbs? On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
28th Apr, 2013 at 09:59:44am
On 28th Apr, 2013 rubicon said:
Make your own inlet and use some bike carbs? I have been reading that bike carbs are good but why? Are they quicker in response? I have some but they are somewhat small. ( they are 1, 25's comling from a gsx 400f race bike i eummm chrashed) i do have 4 of them.) you can do anything if you set your mind to it...
28th Apr, 2013 at 03:08:21pm
No, they will be newer and likely to have less wear, they generally have a newer design depending othe type you get, things like, Butterflied throttle shaft.
28th Apr, 2013 at 04:24:37pm
Hm wont be using these than... they are from the mid 80's. But it all does sound interesting and since i can get my hands on quit some bike carbs...(the breaker is just around the corner) but then it would need a custom plendendiumulum? (Sorry for asking these questions in your topic pauly) Edited by Rammie2000 on 28th Apr, 2013. you can do anything if you set your mind to it...
28th Apr, 2013 at 09:52:56pm
Sorry I was talking about using the carb before the charger. I run a supercharger and I don't care the TB is on the wrong side.
