| Home > General Chat > Anybody heard about the new shell vpower replacement? | |||||||
19th Apr, 2013 at 07:07:55pm
http://www.shell.co.uk/gbr/products-servic...nitro-plus.html
19th Apr, 2013 at 07:16:31pm
99-102 ron ive heard but the friction modifiers that sound interesting Yes i moved to the darkside |
19th Apr, 2013 at 07:22:23pm
And although inhave not read this as im sure its rather un important to joe public but i understand its lighter than normal fuel Yes i moved to the darkside |
19th Apr, 2013 at 08:16:37pm
19th Apr, 2013 at 09:08:07pm
i like the word NITRO .....WTF!......Lol
19th Apr, 2013 at 10:01:22pm
I get talking to the Engineers that do a lot of the initial testing of these fuels. The name V Power Nitro + has been in use in the US for some time already.
1170 Posts Member #: 8636 Post Whore Surrey |
19th Apr, 2013 at 10:05:05pm
Do they pay you well sprocket? Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
19th Apr, 2013 at 10:21:49pm
saying that i do tend to use shell v power over any other premium petrol :) Unfortunately no, I am consideribly under paid as it happens. This is a free service :) On 26th Oct, 2004 TurboDave16v said:
![]() 178 Posts Member #: 10196 Advanced Member |
20th Apr, 2013 at 06:50:12am
Dont know if its a placebo effect but i can definately feel the difference when filling up with v power or bp ultimate, both with the diesel and petrol, although im not rich enough to run my diesel on it all the time :( |
89 Posts Member #: 2380 Advanced Member Hamburg, Germany |
20th Apr, 2013 at 07:48:57am
On 20th Apr, 2013 Cables69 said: a friend of mine drives a Diesel and started to use vpower after it hits the german market, so long ago. after some time he calculated if it's worth it. looking at the figures with regular and vpower diesel he found that the engine used a bit less vpower diesel nearly exactly to compensate the higher price. he thought the engine is running smoother so he sticks with vpower.
although im not rich enough to run my diesel on it all the time :( i even asked my mother to fill her petrol car with Shell 95 octane only and after some time she found that the car uses less fuel, too. same as my old Rover. so it may be not more expensive to use the more expensive fuel in the long run. and i'm not saying Shell is the only good one, my last Mini liked Aral fuel best |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
20th Apr, 2013 at 08:09:50am
Nice report there Colin! On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
20th Apr, 2013 at 08:58:12am
Dont know if its a placebo effect but i can definately feel the difference when filling up with v power or bp ultimate, both with the diesel and petrol, although im not rich enough to run my diesel on it all the time :( i can say 100% my skyline makes alot more power on V-power confirmed with my laptop it also runs on its knock maps and pulls about 6deg timing when running on supermarket fuel in comparison as i got caught short one day
20th Apr, 2013 at 12:08:43pm
I bought 102octane fuel in Germany 2 years ago |
20th Apr, 2013 at 12:12:40pm
The company my dad works for inform them only to use shell vpower fuel if possible, he has a new 525d 4mpg extra on vpower over regular deisel.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
20th Apr, 2013 at 04:32:54pm
On 19th Apr, 2013 Sprocket said:
Shell use all maner of OEM engines to test fuels and run many different tests using highly sophistocated data capture equipment that only multi billion pound companies like Shell can afford. Some tests run 24/7 for upto 3 months or more. One particulalr test uses a run of the mill, modern 4 cylinder petrol engine from one of the big name manufacturers. The fuel rail is split into two, and each of the two parts of the fuel rail is fed a different fuel, one could be anything, such as a cheap supermarket fuel, and the other the development fuel. The engine is run under load in an envirnonmentally controlled cell for the test duration (could be anything up to 3 months or more). Once the test is complete, the cylinder head is removed and the combustion chambers are scraped clean (this includes the piston crown and the back of the valves) and the carbon deposits weighed and measured. we have this facility at work its called the nocking shop and is where the lab set the ron for different distributors such as shell tesco ect great too have a look around and these guys know how to build engines they have to change piston rings and bearing before each test so that all variables are the same Done now needs redoing lol |
20th Apr, 2013 at 04:49:32pm
it'd be interesting to find out the % bio in it, we had a total station down the road (strangely enough its now a shell), and the super basically turned to water within days |
20th Apr, 2013 at 06:06:28pm
Shell V power was the fuel I used in the Metro. It was noticeably better that BP Ultimate. . . On Peter Baldwin's Rolling road he commented my engine loved lots of timing advance and was very powerful given the spec.
![]() 517 Posts Member #: 9931 Post Whore brighton |
21st Apr, 2013 at 07:50:17pm
its 99ron i filled the car up to day with :)
28th Apr, 2013 at 10:04:36am
stuck 30 quid in last night and went for an hour data logging up to andys,
28th Apr, 2013 at 10:30:52am
dont like 5th gear much but found this on youtube
