| Home > Help Needed / General Tech Chat > Mini cooper Spi | |||||||
2 Posts Member #: 8019 Junior Member Lisbon - Portugal |
23rd Apr, 2013 at 12:18:35am
hi everyone, I have a mini cooper Spi from 1993 and I had a problem that I fixed Changing all capilar hoses hoses between the inlet manifold and the ecu. the first problem was the engine revs were to low and the engine stops at idle, when I change the hoses this problem was fixed but at the same time I get new one, now its realy hard to get the engine started, sometimes it starts at the first try but normaly it won´t start.
Edited by bryckon on 23rd Apr, 2013. |
23rd Apr, 2013 at 12:21:07am
If any one can help me I appreciate Edited by bryckon on 23rd Apr, 2013. |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
23rd Apr, 2013 at 11:08:36am
I don't know much about Spi minis.
Dazed and Confused.... |
23rd Apr, 2013 at 11:45:17am
Have had simular problems with my mpi in the past, . It turned out to be the water temp sensor. Saying that spi/mpi are very different systems |
61 Posts Member #: 9748 Advanced Member Bedfordshire |
23rd Apr, 2013 at 12:22:04pm
yes as above, once your car has warmed up does the water temp guage work in the car? if not it could be that the sensor is faulty therfore the stepper motor doesnt know where to put your throttle position to causing it to not start at cold |
![]() 270 Posts Member #: 69 Senior Member Coventry |
23rd Apr, 2013 at 09:11:08pm
Check wiring to the coolant sensor very likely you have dislodged them doing the vacuum pipes, sensor is underneath manifold, when it wont start splash a tiny bit of petrol into the throttle body then put filter housing back on, it will start and once running will run all day, in effect ecu doesnt know temperature and default is warm start at 59 degrees, so starts with no cold enrichment....(choke in old money) |
24th Apr, 2013 at 03:24:18pm
as i mentioned above |
good idea that the wires might have come off!
